Fullscreen is unavailable with -filelist option; Crashes
Feedback and Comments on the new 1.96 Test version on Windows.
rs2009
Post by rs2009 »
If xnview is invoked with the -filelist option, then F11 / View in fullscreen does not work.
Sometimes this (F11/View in fullscreen attempt) results in a crash. It sounds similar to this report since it involves fullscreen and appears to not be caching in this mode.
http://newsgroup.xnview.com/viewtopic.php?t=16741
Ray
Re: Fullscreen is unavailable with -filelist option; Crashes
rs2009 wrote:If xnview is invoked with the -filelist option, then F11 / View in fullscreen does not work.
I can't reproduce, i use -filelist, and i can press F11 for fullscreen without problem...
rs2009
Post by rs2009 »
I think I found the difference:
1. If the photos are on a local C:\ drive, F11-fullscreen works ok.
2. If the photos (not the filelist) are on a network drive and I try F11-fullscreen from the browser window, then it fails.
Note - I can get to fullscreen hitting F11 from a viewer tab.
Note - Perhaps this is also related to the -filelist thumbnail appearing to *not* cache.
Ray
(WinXP)
The thumbnails are not created??
I've tried with pictures on shared folder, and no problem...
rs2009
Post by rs2009 »
Hi Pierre,
Sorry - This was my error.
I had trailing spaces in each line of my filelist.txt file.
After removing my trailing spaces, every thing works as expected.
(I didn't notice the spaces originally, because the browser thumbnails showed up even with the trailing spaces. It was the fullscreen view that caught my error).
thanks again for this feature
Ray
(Perhaps XnView should remove trailing whitespace in the filelist?)
Locked
