Print dialogue: display of papersize
Feedback and Comments on the new 1.96 Test version on Windows.
Peter2
Post by Peter2 »
After a 5-min-quicktest I think that it works, but it is not easy to read (too many information).
Instead of
Page size: 11.7x8.3in; 296.89x209.81 mm
it should have:
- units: only the same that I selected in print dialogue (Layout)
- spaces around "x"
- if possible the name of the norm-format
- other string-content
Page size (mm): A4, 296.89 x 209.81
Page size (cm): userdef., 89 x 250
Peter
Peter2
Post by Peter2 »
Any comments?
Peter
Lesmo16
Post by Lesmo16 »
The string "Page 1/1" *below* the preview is translated to German (Seite 1/1), but not the string *on* the preview.
The string "Page" is the default value for the page footer, and should be automatically changed with language change.
Everyone who believes in telekinesis, raise my hand!
Peter2
Post by Peter2 »
Lesmo16 wrote:...The string "Page" is the default value for the page footer, and should be automatically changed with language change.
I think that is not helpful:
The entry in footer does not come from the software but from the ini-file:
FText=Page <Page>/<Page>
And if you change the footer like you want - and then the software changes it back ..?
Peter
Locked
