XnView 1.96 beta 1
Feedback and Comments on the new 1.96 Test version on Windows.
Moderator: XnTriq
dandv
This beta detects 1.95.4 as a newer version
Post by dandv » Sat Jan 10, 2009 5:53 am
Just installed the beta and was happy to see the rotation being applied to the image only after the user stops typing.
Also noticed that it detects 1.95.4 as a newer version. Is this normal?
pic_viewer
Post by pic_viewer » Sat Jan 10, 2009 11:57 am
When starting from a file via TC into fullscreen view XnView crashes imediately on my Vista system. See also my other crash which might be cache related. I'm back to 1.954 now.
ckv
Post by ckv » Sat Jan 10, 2009 12:40 pm
pic_viewer wrote:When starting from a file via TC into fullscreen view XnView crashes imediately on my Vista system. See also my other crash which might be cache related. I'm back to 1.954 now.
See: http://newsgroup.xnview.com/viewtopic.php?t=16741
I bet it's the same bug.
Moderator & Librarian
Post by XnTriq » Sat Jan 10, 2009 2:45 pm
:D Great stuff, Pierre! Thank you!
JohnFredC
Post by JohnFredC » Sat Jan 10, 2009 5:01 pm
Wow, Pierre. What an ambitious list of changes/fixes/improvements. You've been busy!
Thank you!
John
Post by xnview » Mon Jan 12, 2009 11:13 am
Dreamer wrote:
thibaud wrote:
Mezich is the default, perhaps you had a .ini??
no, removing the .ini file and starting up xnview again also default to old skin (after choosing to use .ini from application folder)
(I noticed this on a fresh install of xnview 1.95.2 also)
Confirmed, Mezich is NOT a default skin.
Oh right
profess135
Post by profess135 » Tue Jan 13, 2009 1:26 am
Thanks for the new 1.96 b1 Pierre.
Is my other post an option?
Regards and thanks again,
Osei
ckit
Post by ckit » Tue Jan 13, 2009 2:22 am
Just out of interest, has anyone tried this new beta under Windows 7 beta 1 (32-bit or 64-bit)?
Windows 10 Pro x64 1909
XnViewMP and Classic and PhotoFiltre Studio X
afloom
Post by afloom » Tue Jan 13, 2009 11:40 am
I get an error message starting the application:
This application has failed to start because MSVCP71.dll was not found. Re-installing the application may fix this problem. Clicking 'ok' then starts the application which seems to work ok anyways.
My environment: Windows XP SP3 (English)
Anything else you need?
/Anders
ckv
Post by ckv » Tue Jan 13, 2009 7:35 pm
afloom wrote:I get an error message starting the application:
/Anders
Don't worry about it. It's just a plug-in with dependency to runtime dll you don't have. The plug-in wont work without the dll file, but otherwise it XnView works normally.
To get rid of the message, you can either delete IlmImf.dll file XnView plugins directory or you can download msvcp71.dll and msvcr71.dll (also required) from internet and copy them in XnView directory.
Locked
