XnView 1.96 beta 1
Feedback and Comments on the new 1.96 Test version on Windows.
Moderator: XnTriq
XnView 1.96 beta 1
Post by xnview » Fri Jan 09, 2009 10:47 am
XnView 1.96 beta 1 can be downloaded here
Here is the changelog:
Added:
* Open GPS in view mode - http://newsgroup.xnview.com/viewtopic.php?t=13859
* SelectedBorderColor in .ini for selected border color of thumbnail - http://newsgroup.xnview.com/viewtopic.php?p=68467
* delay in rotate dialog - http://newsgroup.xnview.com/viewtopic.php?t=16339
* IPTC png readed
* Page size in print dialog - http://newsgroup.xnview.com/viewtopic.php?t=16260
* NConvert: opacity for watermark - http://newsgroup.xnview.com/viewtopic.php?p=68466
* NConvert win: "-out clipboard" to export into clipboard - http://newsgroup.xnview.com/viewtopic.php?t=16313
* Default color profile - http://newsgroup.xnview.com/viewtopic.php?p=65886 & http://newsgroup.xnview.com/viewtopic.php?t=15424
* Color profile can be saved
* Mouse wheel to switch between tab - http://newsgroup.xnview.com/viewtopic.php?t=16400
* Lossless comment edit for PNG - http://newsgroup.xnview.com/viewtopic.php?t=16594
* Slideshow video export
* 'Add text' alignment - http://newsgroup.xnview.com/viewtopic.php?t=16232
* 'Save' overwrite dialog, options added
* opacity support fullscreen & slideshow - http://newsgroup.xnview.com/viewtopic.php?p=68952
* Print size in 'Set DPI' dialog
* Medium lossy for cache - http://newsgroup.xnview.com/viewtopic.php?t=16623
* Ctrl+Alt+A for scan - http://newsgroup.xnview.com/viewtopic.php?t=16110
* Message when loading non RGB picture - http://newsgroup.xnview.com/viewtopic.php?t=15249
* Animated GIF in slideshow - http://newsgroup.xnview.com/viewtopic.php?t=16569
* Param_ in .ini for OpenWith - http://newsgroup.xnview.com/viewtopic.php?p=63936
* IPTC in utf8 correctly viewed
* ICC profile convert in 'batch convert' - http://newsgroup.xnview.com/viewtopic.php?t=15585
* SIF format read support
* Favorites added in browse history button - http://newsgroup.xnview.com/viewtopic.php?t=13929
* LockLayout added in .ini - http://newsgroup.xnview.com/viewtopic.php?p=66311
* cmd_Addon can be added now - http://newsgroup.xnview.com/viewtopic.php?t=15108
* PSD ICC & EXIF & XMP read support
* JPEG2000 ICC read support
* WSQ format read support
* PENTAX makernotes
* File list to command line - http://newsgroup.xnview.com/viewtopic.php?t=16719
* Color picker - http://newsgroup.xnview.com/viewtopic.php?t=16642
* NCONVERT: -icc_in & -icc_out to convert ICC profile
* XNSHELL: scan header - http://newsgroup.xnview.com/viewtopic.php?p=68156
Changed:
* Rewrite lossless iptc code
* Smooth not used for preview - http://newsgroup.xnview.com/viewtopic.php?t=16453
* Animated GIF, decoding now in 32bits to support correclty format - http://newsgroup.xnview.com/viewtopic.php?t=16229
OldGifAni ini setting to use decoding in 8bits
* DPI can be changed in 'Resize' without resampling - http://newsgroup.xnview.com/viewtopic.php?t=10729
* Zoom kept if 'lock zoom' - http://newsgroup.xnview.com/viewtopic.php?t=16434
Fixed:
* Camera RAW not readed correctly - http://newsgroup.xnview.com/viewtopic.php?t=16551 & http://newsgroup.xnview.com/viewtopic.php?t=14583
* Favorite dialog & custom color - http://newsgroup.xnview.com/viewtopic.php?t=16255
* 'Desktop' not collapsable - http://newsgroup.xnview.com/viewtopic.php?t=16221
* Double quote in descript.ion - http://newsgroup.xnview.com/viewtopic.php?t=16241
* Delete Metadata & send mail - http://newsgroup.xnview.com/viewtopic.php?t=16544
* IPTC & content location - http://newsgroup.xnview.com/viewtopic.php?t=16509
* cmd_Copy & cmd_Cut in browser toolbar - http://newsgroup.xnview.com/viewtopic.php?t=16484
* IPTC dialog & copy clipboard - http://newsgroup.xnview.com/viewtopic.php?t=16451
* ISO value for RW2 files - http://newsgroup.xnview.com/viewtopic.php?t=16442
* 'Delete' in folder menu & recycle bin - http://newsgroup.xnview.com/viewtopic.php?t=16441
* 'replace color' - http://newsgroup.xnview.com/viewtopic.php?t=16440
* LDF - http://newsgroup.xnview.com/viewtopic.php?p=68723
* Change timestamp & video - http://newsgroup.xnview.com/viewtopic.php?t=16066
* Show rating/color menu item not checked - http://newsgroup.xnview.com/viewtopic.php?t=16162
* Layout 3 problem - http://newsgroup.xnview.com/viewtopic.php?t=16220
* Zoom & fit - http://newsgroup.xnview.com/viewtopic.php?t=16398
* RW2, PEF, ARW
* RAW & Icc
* JPEG dpi (cm)
* Picture info in status bar when preview is closed - http://newsgroup.xnview.com/viewtopic.php?t=16521
* Slide timer even for video - http://newsgroup.xnview.com/viewtopic.php?t=16560
* XMP update & no ascii characters
* ZIP browse crash - http://newsgroup.xnview.com/viewtopic.php?t=16067
* Seconds added - http://newsgroup.xnview.com/viewtopic.php?t=16001
* Text not erased in view fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=16157
* Rotation (by EXIF) - http://newsgroup.xnview.com/viewtopic.php?p=69622
* Exif software can be added in fullscreen info
* Windows classic tab - http://newsgroup.xnview.com/viewtopic.php?t=16580
* ENTER (for fullscreen) on 2 selected files open view mode - http://newsgroup.xnview.com/viewtopic.php?t=15620
* Tag non image & cache disabled - http://newsgroup.xnview.com/viewtopic.php?t=15703
* Export, no extra saving - http://newsgroup.xnview.com/viewtopic.php?t=15122
* Clipboard problem with Gimp - http://newsgroup.xnview.com/viewtopic.php?t=16151
* Quick slideshow button - http://newsgroup.xnview.com/viewtopic.php?t=16171
* GIF crash - http://newsgroup.xnview.com/viewtopic.php?t=16622
* cmd_BurnCD - http://newsgroup.xnview.com/viewtopic.php?p=69773
* DPX writing with 10bits option
* Batch scanning - http://newsgroup.xnview.com/viewtopic.php?t=16503
* Video contact sheet - http://newsgroup.xnview.com/viewtopic.php?t=14490
* 'Filter by' broken - http://newsgroup.xnview.com/viewtopic.php?t=16161
* Control + select category to select children too - http://newsgroup.xnview.com/viewtopic.php?p=69090
* History & previous folder selected - http://newsgroup.xnview.com/viewtopic.php?t=16585
* Toolbar & 24bits screen - http://newsgroup.xnview.com/viewtopic.php?p=69730
* When view is opened, zoom is not correct & selection not constrain - http://newsgroup.xnview.com/viewtopic.php?t=16574
* 'Show files subfolders' issues - http://newsgroup.xnview.com/viewtopic.php?t=16135
* -capture & window size - http://newsgroup.xnview.com/viewtopic.php?t=16599
* XMP encoding problem - http://newsgroup.xnview.com/viewtopic.php?t=15582
* Some paths not cleared - http://newsgroup.xnview.com/viewtopic.php?t=16061
* 'after save as change name' & 'read ahead' - http://newsgroup.xnview.com/viewtopic.php?t=16278
* 'Save as' default color mode - http://newsgroup.xnview.com/viewtopic.php?t=15393
* EXIF problem on MSBF tiff - http://newsgroup.xnview.com/viewtopic.php?t=16634
* Cineon grey
* Print & copies count
* BLP
* DICOM
* Drag&drop file AND preview loading - http://newsgroup.xnview.com/viewtopic.php?p=66630
* "Strip of images" - http://newsgroup.xnview.com/viewtopic.php?t=16031
* Not possible to change system date for non jpeg files - http://newsgroup.xnview.com/viewtopic.php?p=67147 & http://newsgroup.xnview.com/viewtopic.php?t=16668
* Adjust dialog limits - http://newsgroup.xnview.com/viewtopic.php?t=16650
* Import setting added "ImportFormat" in .ini - http://newsgroup.xnview.com/viewtopic.php?p=69808
0 => CF_BITMAP & CF_DIB, 1 => CF_DIB & CF_BITMAP
* Adjust HLS available on grey picture - http://newsgroup.xnview.com/viewtopic.php?p=70010
* 'Add folder' doesn't add video - http://newsgroup.xnview.com/viewtopic.php?t=16553
* 'Fit window' & video - http://newsgroup.xnview.com/viewtopic.php?t=16692
* Multi monitor window location not restored - http://newsgroup.xnview.com/viewtopic.php?t=13180
* windows size save bug - http://newsgroup.xnview.com/viewtopic.php?t=14022
* 'Read ahead' & backward direction - http://newsgroup.xnview.com/viewtopic.php?p=70251
* NConvert: page number for pdf - http://newsgroup.xnview.com/viewtopic.php?p=69498
* NConvert: watermark order - http://newsgroup.xnview.com/viewtopic.php?p=69499
* NConvert: Default extension - http://newsgroup.xnview.com/viewtopic.php?t=16549
* NConvert: Merge_alpha order - http://newsgroup.xnview.com/viewtopic.php?p=69312
ckit
Post by ckit » Fri Jan 09, 2009 11:49 am
XnView 1.96 beta 1 won't even read my INI file which is in C:\Users\<username>\AppData\Roaming\XnView even after I change it in Options to "User"
Well done, great release... I'll wait for beta 2 I think.
Also can you include "\XnShellEx64" in beta 2 too?
Nevermind, it was your fault for putting your INI in the package, my fault for not checking!
Windows 10 Pro x64 1909
XnViewMP and Classic and PhotoFiltre Studio X
Post by xnview » Fri Jan 09, 2009 12:11 pm
ckit wrote:Nevermind, it was your fault for putting your INI in the package, my fault for not checking!
Houps, so it's ok?
ckit
Post by ckit » Fri Jan 09, 2009 12:13 pm
Yes, I restored the INI from my 3 tier backup system :)
Post by xnview » Fri Jan 09, 2009 12:18 pm
ckit wrote:Yes, I restored the INI from my 3 tier backup system :)
Sorry, i've removed the .ini from zip
thibaud
Post by thibaud » Fri Jan 09, 2009 12:29 pm
on vista 64:
1.Viewer crashes on thisimage (browser is not crashing).
edit: I suspect crashes only occurred on this image because it was the first in the folder (maybe the caching system trying to cache a non existing previous image). anyway it's not crashing anymore.
2.in Viewer: high res jpg (>4MB) images are displayed cutted (large bottom chunk is missing) when going next/prev too quickly. height of the missing chunk is relative to the speed you're navigating. Where is the new caching we are longing for ? (did you decide not to cache images exceeding a certain weight ?)
3. I though mezich skin was default. still skinned with "old toolbar" on fresh install. Replacing it with the "default" one one requires a restart to get the other toolbars to use the proper skin.
Post by xnview » Fri Jan 09, 2009 12:38 pm
thibaud wrote: 1.Viewer crashes on thisimage (browser is not crashing).
I have no crash, you load it, and crash?
Ok, i'll check
Mezich is the default, perhaps you had a .ini??
Dreamer
Post by Dreamer » Fri Jan 09, 2009 5:18 pm
Thank you for the new version, Pierre!
Dreamer
oops66
Post by oops66 » Fri Jan 09, 2009 6:42 pm
Thanks Pierre !
XnViewMP 0.82 Linux X64 - Ubuntu 16.04 LTS - X64
thibaud
Post by thibaud » Fri Jan 09, 2009 9:59 pm
no, removing the .ini file and starting up xnview again also default to old skin (after choosing to use .ini from application folder)
(I noticed this on a fresh install of xnview 1.95.2 also)
RickS
Post by RickS » Fri Jan 09, 2009 10:22 pm
Thanks for the new release, Pierre. The problem with copying from Gimp is resolved and I'm good to go. I appreciate all your hard work and the work of those who assist you in producing XnView.
Post by helmut » Fri Jan 09, 2009 10:50 pm
Wow, what a change log! Thanks, Pierre, for your effort! :-)
I like the colour picker in Automatic crop.
Dreamer
Post by Dreamer » Fri Jan 09, 2009 11:45 pm
Confirmed, Mezich is NOT a default skin.
Dreamer
obelisk
Post by obelisk » Sat Jan 10, 2009 12:34 am
Hi
.lnk files are not showing as thumbs in folders
ckit
Post by ckit » Sat Jan 10, 2009 4:46 am
Thanks for 1.96 Pierre!
I'm sorry for going off at you.
Any chance you could remove "Use XnView Shell Extension" from Options? It causes problems for users like me who have both the 32-bit version and 64-bit versions in different folders installed.
Most users should disable\enable the extension via the BAT files provided anyway.
Locked
