Capture suggestions
lawndart
Capture suggestions
Post by lawndart »
With settings of: desktop, F11, hide Xnview, multiple capture,
save to directory, it might be more useful not to bring Xnview
to the foreground each time F11 is pressed.
Generally, would it be better not to bring Xnview to foreground
upon each capture when Xnview has been placed in background?
This would allow capture without interrupting the non-Xnview
program.
Enabling multiple capture option with the timer mode could add
another feature to Xnview.
Re: Capture suggestions
lawndart wrote:With settings of: desktop, F11, hide Xnview, multiple capture,
program.
Yes, right, i'll fix it.
Dreamer
Post by Dreamer »
program.
I'm not sure if lawndart is talking about this but...
If multiple capture is enabled, multiple dialog boxes are shown - I must click to the Cancel button to all of them and then I can edit/save that snapshots. It's quite annoying - especially if there are e.g. 50 snapshots.
Dreamer
Post by Dreamer »
Dreamer wrote:If multiple capture is enabled, multiple dialog boxes are shown - I must click to the Cancel button to all of them and then I can edit/save that snapshots. It's quite annoying - especially if there are e.g. 50 snapshots.
This bug(?) is still here in v1.80.1.
marsh
Post by marsh »
program.
Fixed. Multiple captures can be placed in a directory without annoyance.
lawndart wrote: Enabling multiple capture option with the timer mode could add
Yes. Like recording a desktop session. The captures would need to be saved into a directory for this to work well.
Dreamer wrote: If multiple capture is enabled, multiple dialog boxes are shown - I must click to the Cancel button to all of them and then I can edit/save that snapshots. It's quite annoying - especially if there are e.g. 50 snapshots.
It is annoying. When multiple tabs are opened, it should not offer to close each one of them.
But how can i know if you it's an error or if you don't want to save it????
marsh
Post by marsh »
There is no problem. These multiple dialogs only happen when [x] 'Only one view opened' is checked. So, multiple captures or import clipboards ask if you want to save view- as they should.
marsh wrote:There is no problem. These multiple dialogs only happen when [x] 'Only one view opened' is checked. So, multiple captures or import clipboards ask if you want to save view- as they should.
But it's the same problem, how to know if you want to save last picture or not??
marsh
Post by marsh »
Should it only ask to save when a view/tab is being closed (not switched)?
Perhaps it could say: "Do you want to Switch/Keep/Close current view?"- if you choose 'Close', it could bring up the 'Save' Dialog.
Dreamer
Post by Dreamer »
If possible, show this dialog box only when I leave viewer or exit xnview, not after each capture...
marsh
Post by marsh »
More capture recommendations (possible problems):
1. I suggest not using F11 as default capture key. -Since F11 is now used to switch to fullscreen, it is an inefficient choice for multiple captures. I use <shift + F11>.
2. Multiple captures need an off-button. -Right now, the only way to turn feature off is to make a single capture. Not using F11 makes this a smaller problem.
Rockbern
Screen Captures
Post by Rockbern »
I have had some trouble using the 'Capture screen' feature in the Tools Menu.
I can only get it to work when I select 'Capture Desktop'. It did work a couple of times using the 'Active Window' options but not now.
I have uninstalled and reinstalled it twice with the same effect.
I am using dual monitors and processors.
