Over-written thumbnail in Shell extension
PSHRutPark
Post by PSHRutPark »
When using the shell extension, the thumbnail is always overwritten by menu text. Thus:
Is there a solution to this?
Operating system is Win XP Pro SP3
Thanks
PETER
Re: Over-written thumbnail in Shell extension
I can't reproduce it, which settings do you use?
Other ShellEx…
:arrow: PSHRutPark
:) Hello !
• It's OK here with XP-Pro SP1…
- I suspect some other shell extension set by another programme to be the culprit …
- You could check all ShellExt you have with a tool like ShellExView then disable them one by one till the defect disappears…
:mrgreen: KR
Re: Other ShellEx…
Clo wrote:... - I suspect some other shell extension set by another programme to be the culprit …
Yes, a while back a user experienced problems using XnView ShellEx in combination with Tortoise, another Shell extension for CVS. In the end the "culprit" was the other shell extension. The same might apply here.
PSHRutPark
xnview wrote:I can't reproduce it, which settings do you use?
I experimented with a number of options, including combinations. But no difference.
I suspect it is a negative effect of one of the other shell functions but I haven't been able to identify which one.
Regarding ShellExView referred to by Clo: my firewall gives a serious warning about going to the author's site. Is the programme clean?
Thanks to you all for responding.
PETER
Quite clean !
:arrow: PSHRutPark
:) Hello !
• The ShellExtView tool is a soft I can guarantee safe for all users, "seniors, teens and pets" like icfu-friend says :D
- I use it for ages, and I've ZoneAlarm which never groused about that site… Very good gratis tool ! You may trust me…
:mrgreen: KR
PSHRutPark
Re: Quite clean !
Clo wrote::arrow: PSHRutPark
:) Hello !
:mrgreen: KR
OK!!
It was ZoneAlarm Suite that threw up the rather emphatic warning!
Later: Have retried downloading ShellExtView but unable to. Can view the author's main page but nothing else. Would you mind testing it?
Thanks
PETER
Gratis is better !
:arrow: PSHRutPark
:) Again…
• I use the gratis version, so I guess that they ought justify the licence fee with such stupid “events”… Image
EDIT : I just went to the NirSoft page before to start that message, no problem !
- Whether you can't get the tool, please contact me via PM here, I'll try to send it to you by e-mail if you wish,
my own version is too old but I keep it 'cause I fixed the French language a lot and I don't wish to do this again…
- I got the newest ZIP, it's only 48.2 KiB…
:mrgreen: KR
PSHRutPark
Re: Gratis is better !
Found version 1.14 elsewhere.
Tried a few options and no improvement.
I'll try downloading from author's site on my linux PC.
PETER
PSHRutPark
PSHRutPark wrote:Found version 1.14 elsewhere.
PETER
Worked fine!
Which ?
:arrow: PSHRutPark
:) Did you discover the boor-programme which has put the mess :?:
:mrgreen: KR
PSHRutPark
Re: Which ?
:mrgreen: KR
No.
I will work on it again later.
