Scanning Multi pages is not working?
Moderators: XnTriq, xnview
Post by Guest »
Hi All,
I am new to XnView. I searched the forum and only found one other post relating to my problem. I would like to scan multiple pages and create either TIFFs or PDFs of these scans. I'm using the "File...Acquire into" Command and making sure Multiple Pages is checked and I'm scanning in as TIFF format. However, when I start scanning, the first page scans and then that's it - nothing happens? It saves the file automatically and I have no further dialog boxes or questions about the procedure. So, my query is, am I doing something wrong? Where is it I can put my second page in and keep on scanning into this file? It just doesn't seem to be working for me. Maybe it's my scanner (Epson CX3100 MutilFunction) but I am asking in case I'm missing something obvious here.
Thanks for any help offered...
Moderator & Librarian
dobrofsky
Post by dobrofsky »
I'm using XnView 1.95.4 with full installation and am using Windows Xp Home. I should also note that scanning multi-page works fine with Microsoft Office Document Image Scanning and my scanner, so the scanner can definitely 'do' it fine. I just think there's some glitch there with XnView as with one of the other posters from those links you listed, after the first page, scanning stops and nothing else happens.
dobrofsky wrote:I just think there's some glitch there with XnView as with one of the other posters from those links you listed, after the first page, scanning stops and nothing else happens.
:bugconfirmed: XnView v1.95.4 / Windows 2000 SP4 / Samsung TWAIN Driver v1.30
Re: Scanning Multi pages is not working?
Please try XnView 1.96 beta
xnview wrote:Please try XnView 1.96 beta
Pierre, with the betas I'm having the same problem as reported by user faulgott in topic “xnview crashing when using batch scan twice”. :?
One normal scan + scan into too?
The crash occurs after the second scan? Do you have the message box?
  1. First, I go to File » Acquire into... and enter these settings in the Batch scanning dialog:
  2. Clicking the Scan button starts my scanner's driver software:
  3. Upon initiating the scan, the TWAIN driver's progress bar shows up:
  4. As soon as the first page is scanned, XnView comes back to the front.
    The progress bar in XnView's status line is moving, which indicates that X:\Scans\tmp_xnview-1.png is created.
XnView is still responsive at this point, but the scanner driver's window stays minimized in the taskbar.
If I go to Acquire into... again, XnView crashes as soon as I click on Scan: “Exception number: c0000005 (access violation)”.
%TEMP%\TWAIN.LOG wrote:
TWAIN_32.DLL - MESSAGE - CTwunk  ::AppInitialize - Reset Log
TWAIN_32.DLL - MESSAGE - CTwunk  ::OpenServer - Starting Thunker
TWAIN_32.DLL - MESSAGE - CTwunk  ::CloseServer - Why Can't We Find The Thunker Window?
TWAIN_32.DLL - MESSAGE - DSM     --DSM_Entry - Nested Call From Source Allowed
XnTriq wrote:As soon as the first page is scanned, XnView comes back to the front.
You don't have a dialog box 'Do you want to continue batch scanning"??
Do you have the same problem in 1.95?
xnview wrote:You don't have a dialog box 'Do you want to continue batch scanning"??
No.
xnview wrote:Do you have the same problem in 1.95?
Yes.
No.
Yes.
I send you a test version
xnview wrote:I send you a test version
Thank you, Pierre :-)
Batch scanning works with the version you've sent me, but the automatic process of compiling the scanned pages to a multi-page document fails.
Let's say I'd like to create a 3-page PDF document:
  1. After each scan XnView asks me: “Do you want to continue batch scanning?”
    I'm clicking on Yes for the first two pages and on No for the third page.
  2. XnView builds test.pdf and then deletes tmp_xnview-1.png & tmp_xnview-2.png.
    The file tmp_xnview-3.png is left behind.
  3. When I open test.pdf in Acrobat Reader, only page 1/3 & 2/3 can be displayed.
    Page #3 is missing.
Acrobat Reader v6.0.5.399 wrote:There was an error displaying thumbnails. There was a problem reading this document (14).
Update: No problems when acquiring into multi-page TIFF!
:D Everything's fine now!
