Changed xnview.ini value causes menu-bar in fullscreen
lawndart
Post by lawndart »
The following xnview.ini values got mysteriously readjusted causing
menu bar to appear in full-screen mode (800x600 desktop resolution):
Width=799 changed to 800 *
Height=572 changed to 600
X=0 changed to 2
Y=0 changed to 1
*Its the 800 value instead of 799 which causes the menu bar to
appear full-screen.
I don't know what caused these values to be reset this way.
Re: Changed xnview.ini value causes menu-bar in fullscreen
lawndart wrote:The following xnview.ini values got mysteriously readjusted causing
X=0 changed to 2
Y=0 changed to 1
appear full-screen.
When xnview reset these values?
lawndart
Post by lawndart »
So far, I have not been able to recreate when values are reset.
Rarely, values can be set manually to exactly 800x600 if windows
start-bar is not 'always on top' and Xnview window is readjusted
in view mode. This can cause window frame to appear in full-screen.
