Background.png + wmfile*.png -> Background_wmfile*.png ?
tireless
Post by tireless »
Lots of Watermark files with one Background image,to make Background_wmfile*.png,how to do that?
this doesn't work:
nconvert.exe -wmfile wmfile*.png -wmflag bottom-right -o %%_new.png Background.png
Re: Background.png + wmfile*.png -> Background_wmfile*.pn
Could you post which result do you would like? And original picture
tireless
Post by tireless »
Is there a way to make below images with one command or nconvert script?
Image Image
Do you have tried with the last nconvert?
tireless
Post by tireless »
xnview wrote:Do you have tried with the last nconvert?
Yes,i did.Very thanks you fixed that problem.
I means,the normal way is execute twice:
Can execute only once?
Do you have tried to use a script file?
tireless
Post by tireless »
xnview wrote:Do you have tried to use a script file?
it works. :)
(i have tried before,and didn't work,maybe i typed wrong words.)
the script file is it right?
### -o 1.png -wmfile wmfile1.png -wmflag bottom-right
### -o 2.png -wmfile wmfile2.png -wmflag bottom-right
