I have plugin for reading raw files that contain elevation maps (raw or dem/srtm files).
Almost works now, but I have one problem - since these are raw files without a header, the plugin displays a dialog window first, allowing user to specify the dimensions, bit depth, various flags about the file (integer/floating point data, signedness, endianness) and rendering options (vertical flip, grayscale, clip ranges). The plugin can also autodetect the image dimensions according to the specified types, using correlation test.
However, herein lies the problem - XnView attempts to prefetch the next image, and if that happens to be a .raw file too, another dialog window is displayed as soon as the first file loads.
I wonder, would it be possible to for example to add something like GFP_NOPREFETCH flag to the support member of gfpGetPluginInfo function, that would turn off the prefetching for files with given extension? Or maybe there is some other solution ..
thanks
Raw+srtm plugin for elevation maps
Re: Raw+srtm plugin for elevation maps
For anyone interested, here's the link to the raw/srtm elevation map reader plugin (I have also edited the link in the initial post).
There's also updated version with many fixes and some additional functionality, like automatic range detection and custom color mapping.
Added support for *.hgt extension, removed *.raw that was often conflicting with raw camera formats. Minor fixes.
New version xhgt.zip, description here.
Encountered an interesting problem - XnView refused to load the extension when it was named just "hgt.usr", I had to prefix it with 'x' making it "xhgt.usr", to force loading it.
Seeking for *.hgt extension support. Could u please redirect me to the thread it has been already mentioned? TIA.
