Truncated labels [All languages]
Group for those who want to contribute in the area of translation of On-Screen texts or Online help of XnView Classic
This topic is for listing truncated labels in the on-screen texts of XnView Classic.
Please report labels that are not fully displayed and truncated by mentioning
- version and your language (e.g. Dutch, French)
- truncated label (in your language)
- English label
Thank you for helping to improve XnView!
1.95 Beta 1 (German):
Following labels are truncated:
"Ausgangsformat beibehalten (wenn möglich)"
"XXX folgende Dateien bei diesen Befehlen verwenden:"
"Um die Schieflage des Bildes zu korrigieren, wählen Sie im Bild eine Linie, die eigentlich horizontal\n sein sollte und wählen dann den Menüpunkt ""Schieflage korrigieren"
"Miniaturansicht in hoher DarsteXXX"
(Note: English original texts are missing, I'll look them up occasionally).
Troken
Post by Troken »
1.94
Swedish.
"Om inga filer har markerats för nedanstående aktiviteter, använd följande inställningar"
English
"If no files are selected, use following files for action"
My suggestion is to simply change the swedish sentece to:
"Om inga filer har markerats, använd följande inställningar"
Moderator & Librarian
French: Édition » Taille de la sélection » Sélection personnalisée
  • Image
Peter2
german truncated
Post by Peter2 »
English:
"Batch Prozessing - Transformations - Convert to Binary - Parameter: No dither"
In german the string "No dither" is translated and truncated to "Keine Rasterung (Di...."
Peter
Dstruct
Some small display bugs in the converter dialog
Post by Dstruct »
XnView 1.96
red mark = problem
Re: german truncated
Peter2 wrote:English:
Still a problem in 1.96 RC1.
@Pierre:
There's enough space for the full German text, could you please just make the label a bit wider?
XnTriq wrote:Image
In 1.96 RC 1 it says "Ordner hinzufügen..:", this does fit.
XnTriq wrote:Image
Yes, "Neuberechnen" is truncated. Perhaps a shorter German translation could be found, or just the combobox moved a bit to the left.
Thanks for the hints, Dstruct. :-) XnTriq has copied them to the right place: Truncated labels [All languages]
Dstruct
Post by Dstruct »
Ok, thanks!
:arrow: helmut
:) Hi !
…or just the combobox moved a bit to the left.
:shock: Are you sure ? :D
:mrgreen: G.
Peter2
Post by Peter2 »
helmut wrote:Yes, "Neuberechnen" is truncated. Perhaps a shorter German translation could be found, ...
"Berechnung"?
"Neu" is not necessary - that is obvious ..
Peter
"Berechnung"?
Yes, "Berechnung" is good and short. Thanks, Peter! :-)
May I change my choice? Perhaps right is better. ;-)
It is !
:arrow: helmut
• Hi !
May I change my choice? Perhaps right is better. ;)
• You may, indeed it is !
:mrgreen: G.
• YEP ! 4000 ! :D
