Nope, XnView 1.94.2 keeps returning to "foo.bar" after any changes are made to the toolbar!
Foo.bar doesn't even exist for f#4k's sake, I'm trying to change the Default.bar!
XnView is DEAD, RIP 2008
Replacement, combo of IrfanView, Ashampoo Photo Commander and Picasa 3 beta.
1.95 b1: Import Clipboard Toolbar Button
Still there !
• The issue is still present in the 1.95 RC1. That night, I noticed that an icon was missing in the browser main tool-bar.
Ckecking the Options, I discovered that XnView had reset the wrong bar file !
- Here, I have :
“Medals.bar” being the right one I'd set some days ago…e:\XnVIew_190_beta\foo.bar
e:\XnVIew_190_beta\Medals.bar
- In the same session, each time I reopen the Options >> Tool-bar, I see the wrong bar again in the upper bar field !
- That's the bug, the most issues with missing icons came from it.
- Temporarily, now I set my INI as “Read only” with the right bar. I'll report what occurs then…
• To reproduce :
1. Have two bars like above,
2. Open any image in View (from a file manager)
3. 2-Click >> Browser
4. Close the browser tab >> Empty View
- !!! The bar has been changed, that can be verified in the Options.
• However, continuing to test, I noticed now that the Clipboard icon is NOT displayed at all
when the pattern of the bitmap is used, it works only with an external *.ICO, example :
works.button10=.\skins\Medals\Ico_Plus\importer_PP_Import_Clipboard_Medals.ico
cmd10=cmd_ImportClipboard
does not work, while it should… Obviously, the #42 pattern is not found by the programme.button10=42
Re: Still there !
???, i can't reproduce this bug! Perhaps you can send me your bar?Clo wrote: • To reproduce :
You have it always? In 1.94.2 too?
I have the correct icon here.• However, continuing to test, I noticed now that the Clipboard icon is NOT displayed at all
when the pattern of the bitmap is used, it works only with an external *.ICO, example :works.button10=.\skins\Medals\Ico_Plus\importer_PP_Import_Clipboard_Medals.ico
cmd10=cmd_ImportClipboarddoes not work, while it should… Obviously, the #42 pattern is not found by the programme.button10=42
