GFLSDK 2.82 Linker error for EXIF editing functions
dominique
Post by dominique »
Hi Pierre,
I have linker problem (C++Builder6) when I use this functions :
- gflFreeEXIF2
- gflBitmapSetEXIFValueInt2
- gflBitmapGetEXIF2
I use "in file" search on the GFLSDK folder and this functions appears only in the header file.
Rgds,
Dom
Re: GFLSDK 2.82 Linker error for EXIF editing functions
Right, please send me your email, and i'll send you a good version
dominique
Exif continued
Post by dominique »
Thank you for sending the corrected libs and this examples (for everybody), it works nice :
exif2 = gflBitmapGetEXIF2( gflBitmap );
GFL_EXIF_ENTRYEX* ptr = exif2->Root;
while ( ptr )
    printf("%x (%d) : %d %d %d  [%u]\n", (unsigned)ptr->Tag, (unsigned)ptr->Ifd, ptr->Format, ptr->NumberOfComponents, ptr->DataLength, ptr->Value );
    ptr = ptr->Next;
gflBitmapSetEXIFValueString2( exif2, 1, 0x010f, "My cam" );
gflBitmapSetEXIFValueInt2( exif2, 1, 0x0128, GFL_EXIF_USHORT, 10 );
gflBitmapSetEXIFValueInt2( exif2, 2, 0xa002, GFL_EXIF_ULONG, 512 );
gflBitmapSetEXIFValueRational2( exif2, 2, 0x829a, 512.0, 200.0 );
gflBitmapSetEXIFValueString2( exif2, 2, 0x9286, "ASCII   <My>" );
gflBitmapRemoveMetaData( gflBitmap );
gflBitmapSetEXIF2( gflBitmap, exif2 );
gflFreeEXIF2( exif2 );
I have images without EXIF information and I'd like to create it like IPTC's function gflNewIPTC. Is it possible to have a gflNewEXIF2 function or perhaps gflBitmapGetEXIF2 can send a blank structure?
Thanks in advence !
Dom
dominique
Post by dominique »
With corrected .lib and .dll sent by Pierre, gflBitmapGetEXIF2 returns a blank structure if there is no EXIF data in the input image.
So every things ok with EXIF now ;)
Dom
