howto search for IPTC tags
Questions, suggestions, and answers for XnView on all Un*x platforms (Linux, HP-UX, AIX, ...)
Moderators: XnTriq, xnview
chris-
Post by chris- »
I just started with XnView for Linux (XnView-static-fc4.i386.rpm).
I do not see, where I can search for IPTC tags? Looked in all menues.
Any hints?
Thanks,
Chris
Peter2
Post by Peter2 »
(For windows):
Ctrl-F
or
Tools - search
or
Context menu in Explorer
for starting the search-dialogue.
Peter
XnView 2.49.4 German, Win 10
chris-
Post by chris- »
Thanks for that. It it true, that this option is not available for Linux? Can't find it on my System.
Chris
oops66
Post by oops66 »
chris- wrote:Thanks for that. It it true, that this option is not available for Linux? Can't find it on my System.
Chris
With Wine and XnView windows v1.94.2:
In tools\search\ ... then only check:"include subfolders" and "IPTC" .....
(FYI: You can also try Digikam in linux because this is very easy to play with IPTC keywords or others tags on it in the "Caption\TAG" tab on the right and for the search function "Tags" tab on left )
http://www.digikam.org/drupal/node/324
I hope than XnView will have this kind of functions in a future version.
XnViewMP Linux X64 - Debian - X64
oops66 wrote: (FYI: You can also try Digikam in linux because this is very easy to play with IPTC keywords or others tags on it in the "Caption\TAG" tab on the right and for the search function "Tags" tab on left )
TAG in Digikam is like Category in XnView win, no?
oops66
Post by oops66 »
xnview wrote:...
Yes almost, Tags in digicam are also inside the digicam.db like Category in XnView.
