XnView Shell Extension 64bit install error
liloli
Post by liloli »
what should I do? thanks!
Actually, I used to use the green version. Both of the Xnview and Extension.
But after I update the Extension files, the "register.bat" file accour such a error.
After that, I tried the setup version, same problem.
Re: XnView Shell Extension 64bit install error
And no problem with old version?
liloli
Post by liloli »
yeah, the old version worked fine.
Could you send me by PM your email (to send a test version), please?
liloli
my mail has been sent
Post by liloli »
thank you!
liloli
Post by liloli »
Great !
It works now !
Thank you ! :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
liloli wrote:Great !
It works now !
Ok, i update the version
liloli
Post by liloli »
by the way, I wonder if things should be like this:
In windows explorer , I right click the pic file, ths thumbnail displays.
When I click the thumbnail pic, the xnview should be open?
Now nothing happen when I click.I think something has broken.
Is there a way to fix it ?
liloli
Post by liloli »
lol, my fault.
I installed the extension in a dir outside the xnview. :?
It's fixed now.
