clarification about license terms
goulding
Post by goulding »
The 'Business license' is worded as follows:
One license per one company or one application. You may not sell or
distribute as a developer toolkit, or use as a server application.
From: "One license per one company or one application", I take that to mean that you can use it within 1 company for as many applications as you want - OR for one application that you can distribute to multiple companies.
Is that the correct interpretation?
Re: clarification about license terms
goulding wrote:Is that the correct interpretation?
yes
ahek
Post by ahek »
Is there a license that allows to re-distribute nconvert along with a commercial application? If yes, which one is it? In this case a library (dll or static) would be great, something like an SDK. Is something like this planned?
Cheers!
ahek wrote:Is there a license that allows to re-distribute nconvert along with a commercial application? If yes, which one is it? In this case a library (dll or static) would be great, something like an SDK. Is something like this planned?
yes you can with site license. sorry but the SDK is no more available.
ahek
Post by ahek »
I thought so :). Thanks!!
