B1: Slide show - window when using FullScreen = 1
Moderators: XnTriq, xnview
Locked
Dreamer
Post by Dreamer » Thu Jun 19, 2008 10:25 pm
Using the following options (below) - the window mode (without a border) is used instead of fullscreen.
# Slide Show Sequence
Timer = 8.000000
Loop = 1
FullScreen = 1
TitleBar = 0
Fit = 1
StrechVideo = 0
High = 1
CenterWindow = 1
ReadErrors = 0
RandomOrder = 1
ShowText = 0
Text = <File> <Filename>
BackgroundColor = 0
FontName = "Arial"
FontBold = 0
FontItalic = 0
FontHeight = -19
TextColor = c0c0c0
TextBackColor = 0
TextPosition = 0
Effect = 0
EffectMask = 16777215
Dreamer
Re: B1: Slide show - window when using FullScreen = 1
Post by xnview » Fri Jun 20, 2008 9:22 am
Ok, will be fixed
Dreamer
Post by Dreamer » Tue Jun 24, 2008 3:40 pm
Not fixed in beta 2.
Dreamer
Post by xnview » Wed Jun 25, 2008 10:43 am
Dreamer wrote:Not fixed in beta 2.
I can't confirm, i have fullscreen
Dreamer
Post by Dreamer » Wed Jun 25, 2008 7:46 pm
OK, it doesn't work only if the sld file is manually changed in text editor:
WinWidth = 640
WinHeight = 480
and...
FullScreen = 0 > 1
I'm not sure if it's a bug or not.
Dreamer
Dreamer
Post by Dreamer » Wed Jul 16, 2008 7:15 pm
It's still the same. Sometimes it's (much) easier to edit one number in .sld file than re-create the whole slide show (few seconds vs. few minutes). So WinWidth / WinHeight should be ignored if FullScreen = 1, if possible.
Dreamer
Post by xnview » Thu Jul 17, 2008 6:54 am
Dreamer wrote:It's still the same. Sometimes it's (much) easier to edit one number in .sld file than re-create the whole slide show (few seconds vs. few minutes). So WinWidth / WinHeight should be ignored if FullScreen = 1, if possible.
Ok :-)
Dreamer
Post by Dreamer » Thu Jul 17, 2008 11:28 pm
Thanks. :)
Dreamer
Dreamer
Post by Dreamer » Mon Jul 21, 2008 11:40 pm
Ok :-)
Fixed in v1.94.
Closed.
Dreamer
Locked
