Hotkeys / Shortcuts Requests
Dreamer
Post by Dreamer »
MrBooth wrote:My number one request for a keyboard shortcut would be for de-interlace, but the ideal solution would be to allow all keyboard shortcuts to be customised (there are some I'd like to be on a single key because I use them a lot), and all functions to have the possibility of a shortcut :-)
Check this - http://newsgroup.xnview.com/viewtopic.php?p=29072#29072 .
Dreamer
darkfader
Post by darkfader »
Hotkeys to move images to preset directories.
Ctrl+F1, Ctrl+F2, and so on.
A preset directory can then also be configured as being the recycle bin.
Too bad Ctrl+F1 is already taken by "Show Favourites menu". That one also has F6 already. Perhaps retain old function when no preset directory is used.
Georg
Post by Georg »
I just discovered Brightness/Contrast/... - Shift+E in All Current Hotkeys / Shortcuts http://newsgroup.xnview.com/viewtopic.p ... ile+select
As usually Hotkey combinations are shown in the menu, show them for image > adjust > * as well. That's my hotkey related wish :) Georg
GeorgD
Rating of images
Post by GeorgD »
In order to rate images, I've to use hotkeys in full screen (popup menu does not contain rating). Great feature, works, efficient :) The bad news: CTRL+1 etc on the numeric keyboard is quite awful on laptops as they don't have a number keypad and toggling is usually not comfortable...is there any reason why not to use the normal numbers? So just 1,2,3,4,5,0? They do nothing so far. Or at least CTRL+1?
/Georg
Not normal here
—> GeorgD
:) Hello !
- That you call "normal" numbers - I suppose on a US Keyboard - doesn't work with a French (and others) keyboard…
- You need +Shift to get the digits, and even with it, that doesn't work in the most cases. :|
- There are threads here where it's reported.
BTW : My son's laptop has a Num-pad…
:mrgreen: Kind regards,
Dreamer
Re: Rating of images
Post by Dreamer »
GeorgD wrote:In order to rate images, I've to use hotkeys in full screen (popup menu does not contain rating). Great feature, works, efficient :) The bad news: CTRL+1 etc on the numeric keyboard is quite awful on laptops as they don't have a number keypad and toggling is usually not comfortable...is there any reason why not to use the normal numbers? So just 1,2,3,4,5,0? They do nothing so far. Or at least CTRL+1?
/Georg
I agree, but only if numpad 2,4,5,6,8 keys would work (to move image, bery old suggestion), maybe it could rate images and move them only if they would be larger than screen. :?: But it would work good only if auto fit feature would be used. Or - rate with non-numpad 1, 2, 3, 4, 5, 0 and move only with numpad 2, 4, 5, 6, 8.
However, rate hotkeys should be one-key-hotkeys, not shortcuts (like ctrl+X, shift+X...) IMO.
Dreamer
GeorgD
Re: Not normal here
Post by GeorgD »
Clo wrote:That you call "normal" numbers - I suppose on a US Keyboard - doesn't work with a French (and others) keyboard…
Well, US, DE, SE, FI and some other layouts I worked often with...so didn't think of FR (only used twice). Hm, not nice.
Clo, simple question: Will CTRL and 1-key (the "normal one") harm in any way? So is some other function activated? If not: Just offer CTRL+1 for the normal and the numpad. French users will not have the choice (sorry) but can still use he numpad hotkeys (as planned before my post), all others have the choice.
Anything else? Dreamer seems not to have a smooth solution as well. Hm. ALT+F1...F5 etc are already used. CTRL+F1...F5 also. WIN-key is not present on IBM Notebooks etc. and badly placed on a lot of others, so not nice as well. Maybe there's a efficient way to determine whether one of the locales with numbers as primary chars of the upmost row is active and only then activate the keys? Yea, no "sober" solution, as hotkeys depend on current locales setting that might even change during XnView is active.
Clo wrote:BTW : My son's laptop has a Num-pad…
Full keyboard? And it still can be called a laptop? Cool 8)
/Georg
With…
:) Hi Georg !
…CTRL and 1-key…
… here needs Ctrl+Shift+1… “As is”, you type Ctrl+&
- It's worse with Alt as a modifier, because the menus hotkeys…
- In XnView, I can't set for example é for a menu while it works in TC for a menu-title!
• The core of the programme is still sticked to a US keyboard, it doesn't care the current keyboard stated in Win. :|
- Aside, did you notice that the dialogues don't contain hotkeys? This is a lacuna that Pierre has to fix up, I worked for this with experimental French DLLs (also an English and German ones for 1.82.x).
- This allows to see the digits issue pretty well ;)
- Personally, I don't care to use the Num-pad always, but it's not sure it be easy to code "normal" OR "Num-pad" digits in all cases.
- I don't use the keyboard a lot because some light handicaps on my hands…
But I guess that the programme must be complete for those who use it.
• Yes, it's a upmarket model… Only the price is not cool :|
:mrgreen: KR
GeorgD
Re: With…
Post by GeorgD »
Hi Clo![quote="Clo"]
So there are no problems caused when CTRL+1 is the hotkey and acceptes the 1 on the numpad as well as on the main keypad? Fine :) one possible solution :idea:
Well, I don't miss that å can't be set as hotkey. There are enough others ;) and sometimes I switch the locale => could not access my hotkey any more.
Yep, but I don't care as TABs / mouseclicks are quick enough for me when only 4 or 6 widgets exist.
Well, depends on the language etc, Pierre can answer this :) and for display in the menu: No problem, only the number is displayed. BTW here's a problem when only numpad works: A lot of users will use the "normal" numbers and be disappointed because the hotkey "does not work". AFAIK there's no way to display normal/numpad distinguished in a common way.
Would be nice as with keys it's very quick and does not disturb during picture show (like a mouse toolbar would do)
*gg* I know what you mean...
/Georg
Dreamer
Post by Dreamer »
New request for...
- ImageShack (plugin) - Shift+I
Added to the list.
Dreamer
bugmenot
Post by bugmenot »
I request a shortcut for "Select only tagged files"
Other image managers that I'd used, have the "º" key for tagging, untaggin and "Ctrl+º" for selecting the tagged files.
"º": I mean the key on the left to the "1".
Thanks!
pepemosca
Post by pepemosca »
bugmenot wrote:I request a shortcut for "Select only tagged files"
Thanks!
One more vote to bugmenot request :wink:
marsh
MMB for revert to original size
Post by marsh »
Currently, the shortcut list displays
"Fit image to window, large only - RMB+LMB"
If Original size=MMB, the other function would be complemented. :idea:
Alternatively, I think the 2 button sequence being 'original size' would be a better match for the existing default viewer setting of: "fit image to window, large only"
bugmenot
Post by bugmenot »
Id like to use my mouse's side buttons for going to the previous/next image.
Windows Explorer and various browsers already support those buttons so itd be nice if XnView supported it too.
martindvorak
Re: Hotkeys / Shortcuts Requests
Post by martindvorak »
I press by mistake ctrl+alt+L. The picture was changed. Can somebody explain me what happend. Thanks Martin
Dreamer wrote:You can make requests for new hotkeys and shortcuts here, or you can start a new topic (for larger requests).
Before posting a request please check here and make sure that it hasn't been requested before and whether this hotkey/shortcut is not reserved for another option. You can find a list of all hotkeys/shortcuts in the XnView Help (press F1 in XnView to show) or here.
If you want support Custom Hotkeys/Shortcuts, you can do it here.
