It's reserved for "Switching modes", you can use RMB and Close, or Ctrl+W.Danny wrote:Here's one of mine:
The possibility to use the middle mouse button to close a tab by clicking on the picture and not the just tab itself.
Hotkeys / Shortcuts Requests
sad to see that they did not implement those hotkeys in the 1.82 beta1...
i've already said that, hotkeys fo automatic level and contrast would be one of the best additions to XnView.
if they don't wanna use the Ctrl + Alt thing, they could use Ctrl + Shift + C/L or anything else...
i don't care which hotkey they wanna choose, i need an HITKEY for those important functions
Please be patient, I wait for some shortcuts much longer (check the list / first post of this topic, most of suggestions are from meTommy wrote:sad to see that they did not implement those hotkeys in the 1.82 beta1...
There is no "programming team", there is just single author - Pierre!i think the programming team could do it very easily
BTW - If you want, you can try new beta (unstable!), there is auto contrast and auto levels in Batch Convert dialog, so you can apply it to all images at once. And - always backup your original images first!
Instead of requesting shotcuts, maybe some flexible solution:
http://newsgroup.xnview.com/viewtopic.php?t=4777
X.
X.
One of the things I find really useful in ACDSee 7 is the ability to Ctrl-Mouseover a thumbnail and have the image appear in the preview pane, then go back to the original preview when the Ctrl-key is released. It's really useful when you're selecting a few of a series of images and there's not quite enough detail in the thumbnails. Is there any chance of implementing such a feature (or is it already implemented and I'm just too dense to find it?)
