Options, History and Favourites for different windows users
Dreamer
Post by Dreamer »
xnview wrote:Why to rename it, you are in the XnView folder ;-)
So by default, now XnView must use Documents and Settings\<user>\Application Data\XnView\ to save xnview.ini instead of XnView folder?
I misunderstood...
First, have you decide to store xnview.ini to path above?
And what about a wallpaprer, same path?
If so, then... If I backup ini files from more different programs, with some backup tool, I choose files xnview.ini and bookmark.ini (because xnview wallpaper.bmp file is huge, e.g. for floppy disk), also 10 or 20 other ini files, it's hard to remember where bookmark.ini belongs...
bookmark.ini
CinemaPlayer.ini
Free Download Manager.reg
MP3DIRECTCUT.ini
MV2Player.ini
PhotoFiltre.ini
vice.ini
xnview.ini
ZipGenius.reg
vs.
CinemaPlayer.ini
MP3DIRECTCUT.ini
MV2Player.ini
PhotoFiltre.ini
vice.ini
xnview.ini
xnview bookmark.ini
ZipGenius.reg
Of course, it's just a minor suggestion, but I think easy to implement, I hope you understood what I meant.
