Annoying copy-paste behaviour
Dreamer wrote:No, I'm for "Select previous folder item" too! I said "Can paste on subfolder item" should be removed, or added as option, disabled by default.
Yes, i means that you are for the option...
Just to be sure - "Can paste on subfolder item" is to paste into the subfolder, right? I think the default behavior should be the same as in explorer and other programs - always paste to the current folder, not to the selected subfolder.
But troken will have always the same problem. He can't paste on current folder.
Dreamer
Post by Dreamer »
But he said:
Im not totally clear about the options anymore, but after Dreamers conclusion, I vote for "Select previous folder item", it has more "+" than "-". If that is standard for other managers, then it should be used I guess.
So he is for "Select previous folder item" too.
If he needs the other option, then you'd have to add two options (to disable the first and enable the other) - but it's not the standard, so perhaps ini options would be enough...
Anyway, default behavior should be as in previous versions, not as in the current version IMO ("Can paste on subfolder item" should be disabled by default).
Dreamer
Troken
Post by Troken »
Hello, have been gone a few days, its always hard to understand this thread after a break. Could we try to summarize the suggestion "Select previous folder item"? Im confused. :)
[ ] "Select previous folder item"
= No subfolder is selected in current folder?
[X] "Select previous folder item"
= One item (subfolder or file) is always selected in current folder. If you i.e. use back-arrow, it remembers the subfolder and selects it?
Is this correct?
Troken wrote:Is this correct?
Yes, but the new option will be "Can paste on subfolder item"
Troken
Post by Troken »
OK, will test it thoroughly when released! :)
But "Select previous folder item" will be always here by default, so a problem for you??
WIth this long long thread, i'm not sure that i understand correctly now :-)
Troken
Post by Troken »
xnview wrote:
Troken wrote:
xnview wrote: Yes, but the new option will be "Can paste on subfolder item"
Weeell... that is the reason for this whole thread. :)
Anyway, if I uncheck "Select previous folder item", I guess that it can help if nothing at all is selected. I'm not certain about the feature, but I'll gladly test it.
Dreamer
Post by Dreamer »
Pierre - "Can paste on subfolder item" will be disabled by default, right?
Troken - "Select previous folder item" option is NOT planned (AFAIK).
I think the ini options would be enough, first disabled and second enabled by default - this is important, it's a standard Windows behavior.
Dreamer
Troken
Post by Troken »
Dreamer wrote:...
Aha, its not an option, its the default setting. I see (I think).
I'll add "Can paste on subfolder item" as option and "Select previous folder item" as ini option
Dreamer
Post by Dreamer »
Problem solved for me, I'll remove the post in ""Must fixes" for next release" topic.
I think also this topic can be closed now, do you agree?
Dreamer
Troken
Post by Troken »
Dreamer wrote:Problem solved for me, I'll remove the post in ""Must fixes" for next release" topic.
I have not tested it because I can not locate the option.
oops66
Post by oops66 »
Troken wrote:...
See here:
Option\Browser\File list\Misc.\Allow pasting to selected subfolder
XnViewMP Linux X64 - Debian - X64
Troken
Post by Troken »
oops66 wrote:
Troken wrote:...
See here:
Cheers oops66. Ok have tested it, I am happy with it now, works very well. I agree that you can close this topic.
Dreamer
Post by Dreamer »
OK, closed.
Dreamer
