1.93.3: Crash on directory change
Grzesiek
Post by Grzesiek »
Try to:
1. View a picture in fullscreen mode.
2. Return to browser with double-click or enter.
3. Try to change directory in tree view.
4. XnView crashes here.
Vista Business 32-bit, PL, Aero On, XnView 1.93.3
ADD: It's not necessary to view the picture in fullscreen.
XnView crashes on nearly any directory change.
Tried on clean ini too.
TheWip
Post by TheWip »
Confirmed!
I have the same problem under Windows XP SP2 : clean system + fresh install of XnView 1.93.3
I am unable to change directory after viewing any image... it crashes.
SP1 OK !
:arrow: All
:) Hello !
• Not any crash here under XP-Pro SP1 !
- Seems OS-related…
:mrgreen: KR
Gast
Post by Gast »
CTD - Crash to desktop with XP Professional SP2 and Directory Change
Cyrlaur
Post by Cyrlaur »
I got it too (Windows XP SP2)
It occurs since there is at least one item selected in right preview panel and trying to change directory (tree panel or preview panel).
rfrancis
Post by rfrancis »
XP Professional SP2
Crashes here too.
Ron
Post by Guest »
I run XP SP2 and got this bug on upgrading from from 1.93.1 to 1.93.2.
I then downloaded 1.93.3 and installed that on the top of 1.93.2, but the problem is still the same.
Luckily I have my entire OS and apps drive imaged, so have reverted back to as it was originally.
I'm not sure if the problem occurs when going straight from 1.93.1 to 1.93.3 as I haven't tried this yet, but thought you should know...
Grzesiek
Post by Grzesiek »
1.93.1 upgraded to 1.93.3 - problem occures
1.93.3 downgraded to 1.93.1 - problem disappears
Same INI in both versions
RazR83
Post by RazR83 »
Grzesiek wrote:1.93.3 downgraded to 1.93.1 - problem disappears
Hm-m, I also downgrade to 1.93.1 & also problem disappers.
xnview, 1.93.4 will soon? :D
RazR83 wrote:xnview, 1.93.4 will soon? :D
I build the package and upload it...
I would like to send a test version to be sure before uploading, so if you are interested, send me your email by PM...
xnview wrote:I would like to send a test version to be sure before uploading, so if you are interested, send me your email by PM...
Currently many people (including me) experience severe problems with XnView. Therefore a test version (release candidate) should be provided to all forum users for checking.
I've put a version here:
http://www.xnview.com/beta/XnView-win-full.exe
Grzesiek
Post by Grzesiek »
xnview wrote:I've put a version here:
And it seems this bug is fixed :-)
Thanks!
RazR83
Post by RazR83 »
Just got 1.93.4 beta.
Problem with crash on directory change are solved. And fullscreen mode on middle button from browser solved too. :D
