GFLSDK - compiling examples
Alex_the_g
Post by Alex_the_g »
Hello!
I downloades GFL SDK and tried to compile examples with MS VC++ 6.0.
But as I loaded workspace and start compiling - I got a lot off errors. Kind like that:
Compiling...
example.c
c:\gflsdk\include\libgfl.h(55) : error C2061: syntax error : identifier 'GFL_INT8'
c:\gflsdk\include\libgfl.h(55) : error C2059: syntax error : ';'
c:\gflsdk\include\libgfl.h(56) : error C2061: syntax error : identifier 'GFL_UINT8'
c:\gflsdk\include\libgfl.h(56) : error C2059: syntax error : ';'
c:\gflsdk\include\libgfl.h(57) : error C2061: syntax error : identifier 'GFL_INT16'
c:\gflsdk\include\libgfl.h(57) : error C2059: syntax error : ';'
and so on. 102 errors all over. Looks like I do something wrong. May you help me to find the problem????
Thanks
Re: GFLSDK - compiling examples
WIN32 is defined?
Alex_the_g
xnview wrote:WIN32 is defined?
Yes.
At least I tried to
#define WIN32 1
to exmple.c and got the same errors.
Which compiler do you recomend to use?
I'll try to reinstall GFLSDK but I think that the problem is easy but not obvious ;(
Thanks.
I have tried the example.dsp project with VC6, and no problem to build it
Do you have basetsd.h?
Alex_the_g
xnview wrote:I have tried the example.dsp project with VC6, and no problem to build it
Yes, It is exist. And I may include it. Doesn't help.
Need more idea :-\
Need more idea :-\
What is the value for INT8 in basestd.h?
Alex_the_g
Need more idea :-\
Confused. No definition of INT8 in basestd.h. And in all the folder \include\ of MSVCPP.
Then I remmed that part of lingfl.h and unremmed old part of that file with old definitions. At least, I built example. Now just need to test it.
Thanks.
