working with RAW files enhancments
mrQQ
Post by mrQQ »
i usually take photos in both raw and jpg formats. With that, i get filename.nef + filename.jpg files. Now, it would be very nice, if i could setup XNView, so that I:
1. Can only load JPG file if both JPG and NEF (Nikon RAW) files are present - this would help to cycle through each photo only once (now each photo is shown only once.
2. Delete associated file when deleting one of pair - if i delete JPG delete NEF, and vice versa.
This would really help a lot..
what do you hink?
mrQQ
Post by mrQQ »
anyone? :(
JohnFredC
Post by JohnFredC »
There is quite a bit of companion file discussion on the forum. If you search "companion" for instance, or "side-car", you'll find several threads.
John
mrQQ
Post by mrQQ »
thanks! i had no idea this was such an extensive topic! i'll just get latest version and see if it has all i need :)
mrQQ
Post by mrQQ »
unfortunately, i can't get it to work. i have added these settings to xnview.ini:
Companion_00=jpg:nef
Companion_01=nef:jpg
Companion_02=xmp:nef
Companion_03=nef:xmp
i have also enabled compaion copy/move.
when i delete jpg, nef isn't deleted. when i move jpg, nef isn't moved. it still cycles through BOTH jpg and nef in viewer.. :(
mrQQ wrote:unfortunately, i can't get it to work. i have added these settings to xnview.ini:
For cycling, it's normal. But for delete/move very strange! Do you have the last version?
mrQQ
Post by mrQQ »
1.92.1 it is..
is in [File] section?
I've tested, and all works. If i copy/paste the jpg or the nef, 2 files are copied. If i delete the nef, the jpg is deleted. If i delete the jpg, the nef is deleted
Perhaps the entries are in a xnview.ini file that is not read by XnView? To verify, please start XnView, change an option and exit it. Then check the timestamp of xnview.ini, it should have the current date and time.
