XnViewShellExt translation: Hints & Discussion
Group for those who want to contribute in the area of translation of On-Screen texts or Online help of XnView Classic
I've just finished the German translation of the XnViewShellExt Version 2.0. When starting the translation translators I had a déjà-vu:
Many strings are used and available in the XnView main program, already. So when translating it's a very good idea to look at the translation of the main program for two reasons:
1.) Keeps the translation of XnView main program and ShellExt consistent
2.) Makes the translation job easier (hopefully ;-) )
Below please find some simple hints for the mapping of strings used in the language file to the main program. I assume that you have the header files of the main program at hand, if this is not the case please contact Pierre and ask for them. Please note that some translations do not match 100%, feel free to shorten or change translations if needed.
The translation of the XnView ShellExtension is kept in a language file, which allows for immediate verification of the translation. You can even make a change and right-click on a file to see your edit immediately.
For a final verification of the translation of the two IPTC dialogs I recommend to open the IPTC dialogs of XnView and the shell extension side-by-side.
I hope this mapping and hints help other translators a bit. ;-)
Mapping of ShellExt strings to XnView main program strings
xnv = Header file 'xnviewxx.h'
str = Header file 'stringxx.h'
[en]
0=English
1=OK
2=Cancel
201=Language
203=High quality for thumbnails --> xnv: #define TXT_Use_High_Quality
204=No thumbnail for EPS/PDF --> xnv: #define TXT_Option_No_Thumbnail_File_Larger
206=Use EXIF rotation --> xnv: #define TXT_Option_EXIF_Rotate
207=Show filename (menu) --> xnv: #define TXT_Option_Show_Filename / #define TXT_Slide_Show_Filename
208=Use submenu
209=Output format: --> xnv: #define TXT_Prop_Format / #define TXT_Thumb_Format
212=Settings... --> xnv: #define TXT_NviewMenu_Options
213=Output folder: --> xnv: #define TXT_Thumb_Output_Directory / #define TXT_Scan_Output_Directory
216=Resize --> xnv: #define TXT_NviewMenu_Resize
224=Convert --> xnv: #define TXT_Convert
_________________________
Dialog: Tools > Options > General > Read/Write > Write]
225=Progressive
226=Optimize Huffman
228=Lowest
229=Best
227=Quality
233=Keep EXIF Data
234=Keep IPTC Data
235=DCT method
237=Smoothing Factor
240=Subsampling Factor
242=Use RLE compression
243=Interlaced
244=Compression level:
245=Color compression
246=B&&W compression
248=Submenu:
Dialog: Edit > Meta data > Edit IPTC data...
1036=Keep original date/time attributes
1041=Load template...
1042=Save template...
1043=Clear
1055=Apply
__ IPTC - Origin
1067=Add
1068=Delete
__ IPTC - Copyright
1071=Add
1072=Delete
__ IPTC - Keywords
1006=Add
1007=Delete
__ IPTC - Categories
1011=Add
1012=Delete
1101=Caption
1102=Caption Writer
1103=Headline
1104=Special instruction
1109=Category (3 char max)
1110=Supplemental categories
1114=Copyright
1115=Byline
1116=Byline Title
1117=Credit
1118=Source
1119=Edit status
1120=Priority
1121=Object cycle
1122=Job ID
1123=Program
1124=Object Name
1125=City
1126=Sublocation
1127=State/Province
1128=Country
1129=Country code
1130=Original transmission reference
1131=Date Created (YYYYMMDD)
1132=Release Date (YYYYMMDD)
1148=Time created
1147=Program version
1149=Release time
1165=Content location code
1166=Content location name
1170=Contact
1171=Defined keywords list:
1172=Defined categories list:
[en-str]
101=Convert into
102=Options...
104=Set Wallpaper as --> xnv: #define TXT_NviewMenu_Set_Wallpaper
105=Best fit to desktop --> xnv: #define TXT_NviewMenu_Fit_to_Desktop
106=Centered --> xnv: #define TXT_NviewMenu_Centered
107=bytes
108=KB
109=MB
110=GB
111=Embedded thumbnail (if available, else 160x120)
112=Thumbnail
113=Convert...
114=Defined size
__________________________
Suggestion: Translate to "Options - JPEG format", "Options - PNG format", ...
115=JPEG settings
116=PNG settings
117=GIF settings
118=PCX settings
119=BMP settings
120=TGA settings
121=None
122=TIFF settings
Dialog: Tools > Options > General > Read/Write > Write > JPEG
123=Slow
124=Fast (worst but fastest)
125=Float (best but slowest)
126=2x2,1x1,1x1 (default)
127=1x1,1x1,1x1 (best quality)
128=Edit IPTC...
129=Choose filename --> xnv: #define TXT_String_Choose_Filename
130=Do you want to write IPTC data? --> xnv: #define TXT_String_Write_Iptc
131=Error writing the file <%s> --> xnv: #define TXT_String_Err_File_Write
Dialog: Edit > Meta data > Edit IPTC data...: Titles of tabs
132=Caption
133=Keywords
134=Categories
135=Credit
136=Status
137=Date / Time
138=Origin
139=Misc.
IPTC - Priority:
140=0: None --> str: #define TXT_String_Iptc_0
141=1: High --> str: #define TXT_String_Iptc_1
142=5: Normal --> str: #define TXT_String_Iptc_5
143=8: Low --> str: #define TXT_String_Iptc_8
IPTC - Object Cycle:
144=a: Morning --> str: #define TXT_String_Iptc_a
145=b: Afternoon --> str: #define TXT_String_Iptc_b
146=c: Evening --> str: #define TXT_String_Iptc_c
147=Delete
148=Clean
Dialog: Tools > Change Time stamp
149=File Creation Date
150=File Modified Date
151=EXIF Date taken (if exist)
152=EXIF Date digitized (if exist)
153=Now
154=Yesterday
155=Clear
156=Write
157=Close
158=No submenu
159=Submenu without preview
160=All
Please note that Pierre has added a string just recently - for this reason it's missing in most translations, e.g. German:
250=Subfolder for converted files
Re: XnViewShellExt translation: Hints & Discussion
Since version 2.0 several strings have been added (current version is v3.1).
In which context is '188=Not detected!' used? Shouldn't this message be a bit more verbose and say something like '<xxx> not detected.' or '<xxx> not detected. Please check <yyy>'?
it's for the File's icon
xnview wrote:it's for the File's icon
Thanks, Pierre. Shouldn't it say something like: 'Source could not be determined.'. Sometimes, the file has an icon (e.g. PDF), but it says 'Not detected.'. Why is that? Is this a bug or when can XnView determine the path and when not?
Non-translatable strings
There seem to be some strings which cannot be translated:
- 'Cancel' in Options dialog
- 'File's icon' in Options dialog
- 'Go to Folder...' (Note: Elipsis should be removed, because action is performed immediately. )
- 'Quality' in PDF options dialog
- 180° (Note: English translation should be changed to 'Rotate 180°' to better conform with the other menu items for rotating)
- 'Choose filename' in dialog for choosing a template file (windows title)
English translation
Some suggestions for the English translation:
167=Rotate 90° right --> Rotate +90° right
168=Rotate 90° left --> Rotate -90° left
Ok
Ok
I agree with 'Source could not be determined'
budz45
Post by budz45 »
helmut wrote: Thanks, Pierre. Shouldn't it say something like: 'Source could not be determined.'. Sometimes, the file has an icon (e.g. PDF), but it says 'Not detected.'. Why is that? Is this a bug or when can XnView determine the path and when not?
The "File's Icon" feature is just reading icon-path info from a user's Registry, so it is sometimes the case that applications installed (e.g. a PDF reader) is Not registering the file-type (and file-type icon) properly or some other interference with the registered file-type in the Windows Registry. I've experienced this too.
'Source could not be determined.' = good idea :P
XnView ShellExt 4.1
'Resize' in Menu
helmut wrote: Sat Apr 04, 2020 9:53 pm XnView ShellExt 4.1
'Resize' in Menu
Right
