gflCrop and GFL_RECT
madiazg
Post by madiazg »
Hello, I have a problem with gflCrop and GFL_RECT.
if:
var
  AreaAjusteFino : PGFL_RECT;
AreaAjusteFino.x := 10;
then Error: Access violation at address...
but
  AreaAjusteFino : TFL_RECT;
  e2 := gflCrop(gfl_bmp2,nil,AreaAjusteFino)
then 'Incompatible types: PGFL_RECT and TGFL_RECT'
What am I doing badly?[/code]
I am using Turbo Delphi .
Regards...
Re: gflCrop and GFL_RECT
I don't know very well Delphi, but i think you must use TGFL_RECT
gispos
Post by gispos »
madiazg wrote:Hello, I have a problem with gflCrop and GFL_RECT.
if:
var
but
Regards...
PGFL_Rect is a Pointer !
You must get memory like New and finally Dispose or use this:
AreaAjusteFino : TGFL_RECT;
e2 := gflCrop(gfl_bmp2,nil,@AreaAjusteFino)  // operator @
or
pR: PGFL_RECT;
R: TGFL_RECT;
pR := @R;
pR.x := 10;
Gruß gispos
madiazg
Post by madiazg »
Thank you very much.
