New Addon "PhotoMasque" for 1.92
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
A new addon made by the great author of the graphic program Photofiltre (Antonio Da Cruz) is available here, so please give us your feedback!
Moderator
Re: New Addon for 1.92
xnview wrote:A new plugin made by the great author of Photofiltre (Antonio Da Cruz) is available here, so please give us your feedback!
This new AddOn "PhotoMasque" provides really good effects. :-) Some brief info:
What PhotoMasque does:
PhotoMasque overlays the currently opened image with a mask - this way you can create special borders and other effects. Various masks are provided e.g. snowflake, fog, keyhole, and some more.
Screenshot: Applying a mask with PhotoMasque:
Installation
"PhotoMasque" is an AddOn for XnView. To install it, you extract the downloaded ZIP archive in the folder "AddOn". Then you (re)start XnView.
If installed properly, XnView will list PhotoMasque as AddOn in the PlugIn info dialog, which you can open via menu "Info > PlugIns Information", in the drop down list select "AddOns".
Using PhotoMasque
For starting PhotMasque, you ...
1. open an image in view mode.
2. select menu item "Filter > PhotoMasque (1.0)".
3. Open a mask by clicking on the folder icon right to the edittext "Mask".
4. In dialog "Open" select one of the masks provided. (you can use own mask files, also).
5. Confirm "Open" dialog with "Open".
6. Activate checkbox "Preview" for seeing a preview of your mask and settings.
7. Changes settings (Opacity, Color, ...) as desired.
8. Confirm with "OK".
Drahken
Post by Drahken »
Works pretty well. (Although it'd be really good if xnview supported saving images with alpha transparency.)
One minor bug though, the preview option doesn't remain checked after you apply the filter, you have to check it again the next time you go to use it.
And also…
:arrow: Drahken
:) Hello !
…(Although it'd be really good if xnview supported saving images with alpha transparency.)…
• Indeed, I guess that could improve the final result…
…One minor bug though, the preview option doesn't remain checked after you apply the filter…
• Right, I confirm, that's so irritating…
• Also, I dislike the colour-palette and its auto-close feature.
- For once, I much prefer the old good Win one (with several saved custom colours, like we have now in XnView).
• To process relatively small images, we miss other masks¦patterns having smaller and denser items.
- For instance, with snowflakes on a pic W=251 - H=301 pixels, the items are too big and spread,
it doesn't result in a very realistic effect.
- I drew a denser one (from the smallest items), it's better but not wonderful yet…
• But it's a good start, and definitely a very useful add-on which improves XnView a lot !
:mrgreen: KR
Not needed
:arrow: helmut
• Hi !
…If installed properly, XnView will list PhotoMasque as AddOn in the PlugIn info dialog, which you can open via menu "Info > PlugIns Information", in the drop down list select "AddOns".
• You are not bound to do so. When the files are in the <AddOn> sub-folder,
XnView creates a “dynamic” entry in the View Mode >> Filter Menu.
¤ Aside : BTW, this “dynamic entries” feature could be¦is an issue to solve before we switch to menus as text…
:mrgreen: G.
Drahken
Post by Drahken »
No transparency:
http://allspark.net/cypherswipe/frame-1.jpg
Single color transparency (what xnview can do):
http://allspark.net/cypherswipe/frame-2.png
Alpha transparent (note, you need a real browser such as opera or fifrefox to view this one properly online, or at least IE v7. IE v6 and earlier lack alpha transparency support):
http://allspark.net/cypherswipe/frame-3.png
marsh
2 dialogs there
Post by marsh »
Clo wrote: • Also, I dislike the colour-palette and its auto-close feature.
Both dialogs are there. :) Select colour bar instead of down-arrow for old, larger style. A bit unexpected.
Moderator
Re: 2 dialogs there
Wow, well spotted, marsh! :-)
Peter2
On addon-download page?
Post by Peter2 »
Why is that addon not on the addon-download page?
http://pagesperso-orange.fr/pierre.g/xn ... ddons.html
Peter
XnView 2.51.0 German, XnConvert 1.95, Win 10
Re: On addon-download page?
Peter2 wrote:Why is that addon not on the addon-download page?
It's fixed :-)
Peter2
Post by Peter2 »
Peter
Gone again? I can not find it - neither in English nor in German.
Peter
Moderator & Librarian
Re: New Addon "PhotoMasque" for 1.92
@Pierre: The link is missing on the official dowload page.
PhotoFiltre-Studio.com ([url=http://www.photofiltre-studio.com/addones-en.htm]Add-ons[/url]) wrote:Masks for the PhotoMasque module
Unzip the files in the directory “Masks” of PhotoFiltre
(You can create sub-directories in the main “Masks” directory)
You can find and post more masks in the forum
