Problem saving 16bit TIFF image
MasA
Post by MasA »
Hi!
I've got a "Bad format index" message... Here is the code
    int bits = pow(2,16)-1;
    AnsiString plik = *fname;
    GFL_ERROR error;
    GFL_COLOR color;
    GFL_BITMAP * bmp = gflAllockBitmapEx(GFL_RGB, G[G.High][0].Length, G[G.High][0][0].Length, 16, 3, NULL);
    GFL_SAVE_PARAMS params;
        gflGetDefaultSaveParams(&params);
    for(int x=0; x { G[G.High][0].Length; x++){
        Application->ProcessMessages();
        for(int y=0; y { G[G.High][0][0].Length; y++){
            color.Red = (unsigned short)(G[G.High][0][x][y]*bits);
            color.Green = (unsigned short)(G[G.High][1][x][y]*bits);
            color.Blue = (unsigned short)(G[G.High][2][x][y]*bits);
            gflSetColorAt(bmp, x, y, &color);
            tp->PB->Progress++;
    error = gflSaveBitmap(plik.c_str(), bmp, &params);
    if(error) MessageBox(NULL,gflGetErrorString(error),"Ups...",MB_OK);
    gflFreeBitmap(bmp);
I've change "<" symbol to "{" becouse code got errors when showing on the forum.
Where "G" is big Array where I store float numbers (0...1). Where is problem ??
MasA
Re: Problem saving 16bit TIFF image
You must add params.FormatIndex = ....
MasA
Post by MasA »
...so simple :)
thx for help.
Great image library !!!
MasA
