[OK] Lock zoom not indicated, locked position
Dreamer
Post by Dreamer »
Mini-bug - if lock zoom is enabled, images are not centred...
Also I can't see if lock zoom is enabled or disabled, maybe we need this in the context menu:
|\/ | Lock zoom (enabled)
|   | Lock zoom (disabled)
And same for Fullscreen, it's not sure, it's for leave fullscreen now...
Well spotted, Dreamer: ;-)
Currently, there is the menu item 'Lock zoom' in menu 'View'. When activating it, there is a hook indicating that this option is activated. But this hook never appears in the context menu (both view mode and fullscreen). This is a (small) bug which I confirm.
- Locked position
For some people the locked position (=not centered) is very helpful, since the combination of locked zoom and locked position together allows for comparing two images of same size by navigating back and forth. But for other people the locked position is not so nice. So perhaps there should be sub-setting of Lock zoom:
[x] Also lock position when using Zoom lock
Re: Lock zoom not indicated, locked position
Dreamer wrote:Mini-bug - if lock zoom is enabled, images are not centred...
Not centered???
Ok, i'll fix it.
Dreamer
Post by Dreamer »
Not centered???
Try this: (in fullscreen, but it's also in viewer)
- zoom image
- (now image is centred)
- lock zoom (ctrl+/)
- go to the next image (page down)
- go to the previous image (page up)
- (now image is not centred)
(I'm not sure what word is right 'centred' or 'centered')
Remains OK
:) Hello !
- I cannot confirm this under Win 98 SE.
- I followed the steps you describe, and the image stays centred { :) U.K. } / centered { :( elsewhere… }
:mrgreen: Kind regards,
Dreamer
Re: Remains OK
Post by Dreamer »
Clo wrote:- I cannot confirm this under Win 98 SE.
I've got Win XP SP1, but I don't think it's important here...
Try zoom larger images and also with default settings...
Dreamer wrote:Try this: (in fullscreen, but it's also in viewer)
- zoom image
Can't reproduce the problem :-(
centered :-)
Tss,Tss---
>> Pierre
:) Good morning!
• Harrap's :
(Fr.) centrer [sStre] vt to centre, US to center (sur, on);
:P
Dreamer
Post by Dreamer »
- zoom image
Also with default settings? Strange...
Dreamer wrote:
- zoom image
Someone has the same problem?
Dreamer wrote:
Not centered???
- zoom image
My initial answer above regarding locked position was wrong: There used to be something like a 'Locked position' when locked zoom was active. Then, when navigating to a new image the same area of the image was displayed as before.
But in XnView 1.74 this is no longer the case: Whenever navigating to an image, the top-left corner of the image is displayed. This happens with or without locked zoom.
Not sure whether you mean this.
Dreamer
Post by Dreamer »
Yes exactly this!
Yes exactly this!
Ok, i understand now ;-)
And there is perhaps another problem.
For example, if i have the fit option "large only", i view a little picture so zoom is 100%, i lock the zoom, and view next file. Now this picture is big.
But the zoom becomes 50%, because of the fit option.
Do you think that this is normal?
xnview wrote:And there is perhaps another problem.
Right, another Zoom bug.
Dreamer wrote:
helmut wrote:...
Yes exactly this!
Think that's a feature which hasn't changed for ages. Do you think that it's better to view the center of an image?
Locked
