Show information about the current zoom in fullscreen
Locked
Dreamer
Post by Dreamer »
Another suggestion - show information about the current zoom in fullscreen (view > fullscreen > show information)
Example - 50%, 100% , 400% , 586% ... (it means even if zoom is done with a mouse - select and click, not only standard zoom 200, 300, 400, 500%...)
Re: Show information about the current zoom in fullscreen
Dreamer wrote:Another suggestion - show information about the current zoom in fullscreen (view > fullscreen > show information)
The current zoom value as another place holder that people can use in the information. Sounds like a good suggestion to me.
Perhaps this could be refined, e.g. in fullscreen mode the Zoom value could be displayed whenever zoom is changed and then disappear after some few seconds. Or Zoom value could be displayed only, when it's not 100%.
(Not really sure which of these are really useful and needed by users.)
Dreamer
Post by Dreamer »
helmut wrote:Perhaps this could be refined, e.g. in fullscreen mode the Zoom value could be displayed whenever zoom is changed and then disappear after some few seconds. Or Zoom value could be displayed only, when it's not 100%.
I was thinking about it too, but... It would be more complicated to implement and not all images in fullscreen are at 100% zoom - if some of "fit image to window..." options are enabled...
...So I think, "show as fullscreen information" is enough... please read also Fullscreen informations (I think this is a better way...)
You want to be able to add item in "show informations" to show the current zoom?
Dreamer
Post by Dreamer »
xnview wrote:You want to be able to add item in "show informations" to show the current zoom?
Yes, exactly, like in status bar...
(And could you look at Fullscreen informations and this too, please?)
Locked
