"Compressed [silver]" extracted to XnView rootfold
Jota.Ce
Post by Jota.Ce »
That web template folder is extracted to XnView folder, and not on WebTemplate subfolder.
I've verified on 1.91.2 and 1.91.3 versions (complete edition)
And... a tiny bug i also found on 1.91.2 and .3.
When i open a photo in edition mode and set Color Information (Ctrl+Shift+I) option to enabled, XnView forgets it for the next time i enter there.
But it's even worse: if you're on edting mode and enable that option, it works. But if you clik on Next or Prev button (next image/previous), it is disabled again.
No bug
—> Jota.Ce
:) Hello !
• There is no bug with the “Colours Information”, please have a glance HERE ;)
:mrgreen: Kind regards,
Jota.Ce
Post by Jota.Ce »
I didn't know XnView had extra non-GUI options.
But... it's GREAT !!!
I've the param left in position 2.
Thanks Claude. Now, the easy-to-solve problem with the WEBTemplate (for the next version).
Regards for all the XnView project people ;)
marsh
Re: "Compressed [silver]" extracted to XnView root
Post by marsh »
Jota.Ce wrote:That web template folder is extracted to XnView folder, and not on WebTemplate subfolder.
I have no problem with any archive. Perhaps your compression program is bugged?
Jota.Ce
Post by Jota.Ce »
I mean:
EXE installer extracts the folder "Compressed [silver]" in XnView directory. And that's wrong, since that folder is a html/css template and should be located in the WebTemplate directory.
It's not a problem of mine, but the installer (at least, the complete version installer).
Jota.Ce wrote:I mean:
Yes, right
Olive
Post by Olive »
It's somewhat surprising that that template is in the exe given that it isn't in the zip, unless I've overlooked it.
