Preferences (F12) are reset at next start
scw2wi
Post by scw2wi »
When I change my settings (F12),
close the program and start it again,
some settings are sometimes reset to default.
There are not always the same settings reset,
but sometimes also the preview window is gone.
I'm using Windows Vista.
Is there any bug known, which could cause this?
Re: Preferences (F12) are reset at next start
scw2wi wrote:When I change my settings (F12),
No i have no problem, but for which settings of option dialog?
scw2wi
Post by scw2wi »
It's not always the same settings that are reset to default.
Here are the settings that where reset at todays start:
(I'm writing the settings in german and try to translate in english, hope this is ok)
Allgemein | Lesen/Schreiben | Schreiben | JPEG | Bisherige Qualität schätzen und verwenden
Common | Read/Write | Write | JPEG | Use existing Quality
(This checkbox was set but got deactivated somehow)
Bildansicht | Verschiedenes | Zwischenspeicher | Aktuelles Bild zwischenspeichern
View | Misc | Cache | Cache actual picture
(This checkbox was set and got also deactivated somehow)
Systemintegration | Eintrag "Betrachten mit XnView" dem Kontextmenü hinzufügen
Systemintegration | Add Kontextmenu-Entry "View with XnView"
(This checkbox got also deactivated today)
Last week, the configuration for the EXIF Information was reset to the default value, but the change of approx. 10 other settings was kept.
It is very strange and not always reproduceable.
Walter
scw2wi wrote:It is very strange and not always reproduceable.
Yes, really strange you are the first user with such problem!
scw2wi
Post by scw2wi »
This problem does not occur any longer (since V 1.95)
All settings keep stable, even when a new version is installed.
Walter
Moderator
scw2wi wrote:This problem does not occur any longer (since V 1.95)
Good to hear that this is solved and thank you for giving feedback, here.
So this issue is solved. :-)
avabaska
Post by avabaska »
I have almost identical problem. Ver. 1.97. Today start Viewer and all settings are default. :o I guess xnview.ini is now by default too. Can you imagine, what feelings I have now :o Very good, that I have this program on other PC and with the same settings, so just copied xnview.ini with replace. From now on I will make a backup of this file regularly.
