Nikon NEF file
pjp
Nikon NEF file
Post by pjp »
I have problem with Nikon RAW/NEF. I have scanner Nikon LS 50ED. This scanner have more file types for save, one of this type is RAW/NEF. When I use Nikon sw, I see this picture as 5397x3580 px, but if I use XnView same picture have only 320x212 px.
Unfortunatelly, this file have appr. 115 MB ... :-(
Regards
Pavel
Re: Nikon NEF file
pjp wrote:Hi,
Other software can scan correctly??
pjp
Post by pjp »
What you mean "Other software can scan correctly??" ?
It's scan good with Nikon's sw, other sw I didn't check/I don't have. I have problem only with show in XnView. TIFF file works good with XnView and now I use this picture format, but on begin I used NEF.
Pavel
pjp wrote:What you mean "Other software can scan correctly??" ?
Pavel
Sorry but the problem is scanning or loading the file?
pjp
Post by pjp »
With loading.
Scan with XnView I didn't check.
Pavel
pjp wrote:With loading.
Oh ok. Could you send me the file?
pjp
Post by pjp »
Small problem - 115MB size ...
OK, I check some possibility at evening.
Pavel
pjp
Post by pjp »
Link sent by private messege with some info.
Pavel
pjp wrote:Link sent by private messege with some info.
Pavel
Ok, thanks. The problem is that Nikon scan files are not compatible with dcraw!! I have seen that lightroom have problem too...
pjp
Post by pjp »
OK, strange, one reason more to don't buy lightroom ... ;-)
I didn't check other non Nikon sw, I can, but no early as next week.
Pavel
