Batch conversion with subfolders?
barsk
Post by barsk »
There is a function to restore the subfolders when batch converting a number of files. However the top folders are missing when I do this. I only get 3 to 4 levels of subfolders, all the top folders are missing. Why is this?
Is there a workaround?
I need to convert a file tree with images in tiff to en exact copy of the file tree, but with jpegs instead.
Re: Batch conversion with subfolders?
barsk wrote:There is a function to restore the subfolders when batch converting a number of files. However the top folders are missing when I do this. I only get 3 to 4 levels of subfolders, all the top folders are missing. Why is this?
XnView restore the common folders between files, it doesn't restore the exact folder tree.
barsk
Post by barsk »
What do you mean, between files?
Why not restore the exact file tree as is? That would be simpler to understand for all. Now it is simply confusing and not usable.
Hoping for a fix... :-)
Regards
Barsk
So if you have selected such files:
and you convert them into \newfolder
You want to have:
Right?
Do you agree (for others users :-) )?
