You means in the xnview package?martin10018 wrote:Any news on this, Pierre? Do you plan to include it in XnView in the near future?
XnView Media Detector
xnview wrote: Yes, i'll enhance it. Perhaps could you make a priority list?
1/ Transfer of all photo types eg jpg, tif nef etc (not just jpg).
2/ Select and assign multiple categories.
3/ Are the IPTC templates the ".ipt" files and where are they currently to be located to be listed in drop-down list? If the answer to the first part is "yes" then it would useful to be able to set the location of IPTC templates.
2/ Dual destination. For example "target" folder and back up folder.
Thanks
PETER
Try it.
Prio # Enhancement
1 # Transfer all pictures inc. RAW (CamTOPC has a problem with NEF as i know)
1 # Enhance naming especially for exif time in the file name.
2 # Add IPTC templates or values to the tranfered pictures
2# Rotate picture according orientation tag
3 # select and add categories ( after it is defined how categories work in the future , see other threads)
3 # add dual destination ( can probably solved if you can start an additional programm as postaction with parameters)
Thats my proposal.
more suggestions? Please deliver input and we will discuss the priority.
Prio # Enhancement
Thats my proposal.
Re: XnView Media Detector
I've updated the version (1.6.0).
Changelog:
* RAW supported
* Companion file support
* auto rotate
* Dual destination
* EXIF template
* Skin system no more used
Changelog:
* RAW supported
* auto rotate
* Dual destination
* EXIF template
Thanks Pierre.
I look forward to testing it. Hopefully later today.
PETER
Does your "EXIF template" statement refer to IPTC. How does it work?
PETER
EXIF can be used in output filenamePSHRutPark wrote:Does your "EXIF template" statement refer to IPTC. How does it work?
Great update! Thanks!xnview wrote:I've updated the version (1.6.0).
Maybe should make the download official on the website?
Where are the settings stored?
Great piece of software, thanks!
Just two things: the "rename by numbering" option doesn't seem to work on my XP system -- e.g. when I want to rename the files to "image##.jpg", instead of replacing the "#" with the actual number, the Media Detector tries to write all files on my CF card to a single file called "image##.jpg" (i.e. it constantly tries to overwrite this single file).
Second, the Media Detector detector doesn't open XnView to show the files after downloading (I use XnView 1.91.6).
Best wishes!
Frank
Best wishes!
Frank
It is the same case for me under Windows 98.Anonymous wrote:Great piece of software, thanks!
Best wishes!
Frank
But , you can try to rename like this (and keep the number of original file <r>) :
rename:
file name:
image_<r>.%e
or
<c1> <c3> <c4>_<r>.%e
XnViewMP Linux X64 - Debian - X64
same for me no matter if you use # or ## or #####
It ever prints a # in the file name not a number. Also i have problems to copy the files to two destinations. The second destination will be empty after the import. Directory is created but the file runs in an error because the file no longer on the source. If you switch on file deletion the file seems to be deleted before it is copied to the second dir. Also if you open xnview after the transfer it opens in the second directory not in the first specified. A progress indicator would be good. (it could be that i see nothing because i tried only with a couple of files and the most time will be used to rotate and to write catedogries and IPTC).
Something else: RAW picture are not shown in the first dialog but they are included in the file list and they are transfered (tested with PEF and DNG)
during the test with DNG i saw that the following JPG picture does not have IPTC data included. If i do the same using PEF as RAW format it works the next piture (all JPG) having IPTC included.
If xnview is not running and you click to see the pictures after the transfer. Xnview is not starting (testing using XP)
Also one additional suggestion:
Is it possible to add a dialog (only one line text input)during the directoy creation so you can specify a variable text (entered in a dialog) than the import date as an example. This would enable the possibility to add "free text" without modifying the options.
But nevertheless this helps me to forget other tools to transfer. Great job. Really.
