I made a slide show and created an exe file from that with XnView.
Due to some ID 10-T -problem I deleted those images but still have the exe.
Apart from clicking through the exe, making screenshots, and cropping them afterwards: is there a way to get the original images out of the exe file?
Extracting original images from a slideshow exe-file?
Re: Extracting original images from a slideshow exe-file?
In EXE you have the jpeg version of pictures, so it's possible to extract these pictures... Send me the exe fileCrysler wrote:Hi,
Pierre,xnview wrote:In EXE you have the jpeg version of pictures, so it's possible to extract these pictures... Send me the exe fileCrysler wrote: I made a slide show and created an exe file from that with XnView.
I am in the same situation as Crysler.
Can I send you my exe file to get out the original jpg pictures ?
yesAccio wrote:Pierre,xnview wrote:In EXE you have the jpeg version of pictures, so it's possible to extract these pictures... Send me the exe fileCrysler wrote: I made a slide show and created an exe file from that with XnView.
I guess it's not that Pierre want to keep a secret, it's because it's a bit complicated to extract the JPG images stored in the slide file. As there are more and more people asking for a way for extraction it might be a good idea to describe it, even if it was long winded or many steps.moi wrote:cant you tell me here how to get the pictures out there![]()
damn please
A simple way of getting the images stored in the slide show executable is by taking screenshots during slide show and storing each single image.
A command line parameter (e.g. "-extract") which extracts all files from the slide show rather than displaying the slide show might be a good future enhancement.
Sorry for not at first describing what I finally did to resolve the problem.
Here's how to extract a jpeg (repeat for each stored jpeg inside the exe):
1) Check a regular jpeg with a Hex-Editor for some characters at the start and at the end that are the same in each file assuming they describe how a jpeg has to be coded.
2) Search for those start- and end-characters in the exe file. Delete all code before and after one of the finds and save the result as a file with the extension .jpg.
3) Load the exe again (or undo the deletion) and continue with the second finding of these chracters (=file) and so on.
A powerful freeware Hex-Editor that does this job is HxD.
or you can ust use this program
http://www.wex.cn/dwing/download/xjpg.7z
in DOS .. in just
xjpg.exe yourslide.exe
it would extract the jpg files..
in DOS .. in just
XnView Arabic Support
Re:
Apologies for the necro, but that link is dead. I found the file on a russian forum (maadjordan wrote: Fri Jul 27, 2007 10:02 am or you can ust use this program
in DOS .. in just
