Dial-a-fix
All non-XnView related: softwares, formats, imaging, photography...
ckv
Dial-a-fix
Post by ckv »
Dial-a-fix
Dial-a-fix is an advanced utility for 32-bit versions of Microsoft Windows that repairs various Windows problems.
Dial-a-fix (hereafter known as "DAF") is a collection of known fixes gleaned from Microsoft Knowledgebase articles, Microsoft MVPs, and other important support forums, that will assist you in repairing problems with your system. Although this tool is ordinarily meant for power users, technicians, and administrators, it is quite safe to use even without technical guidance (although guidance is recommended).
DAF works on all pertinent 32-bit versions of Windows: 98, 98SE, Me, 2000, XP, and Server 2003. Dial-a-fix dynamically disables functions that are not applicable to your version of Windows. The version of Windows with the most support and functionality is currently Windows XP.
http://wiki.djlizard.net/Dial-a-fix
Download Dial-a-fix
