Convert/Adjust/Resize/Sharpen dialog
What do you think if i use only ONE dialog for Convert/Resize/Adjust/Rotate/Sharpen?
Re: Convert/Adjust/Resize/Sharpen dialog
No reply??xnview wrote:What do you think if i use only ONE dialog for Convert/Resize/Adjust/Rotate/Sharpen?
- tbryson92110
I know this is an old request, BUT I definitely think one dialogue would be terrific!
I think it would be an improvement. If the screen is too small to fit all controls, you could make separate tabs (the preview would show the combination of all effects vs the original)
