Difference between Slide show and Quick-show?
Troken
Post by Troken »
What is the difference between "Quick-show" and "Slide-show" in the browser? Using the different ends up with the same tool, I suspect that the "Quick-show"-button should be named "Slide show"?
In the viewer the "Quick-show"-button reacts differently.
Dreamer
Post by Dreamer »
There are no effects in Quick slide show and you can run it any time by Pause hotkey, you can find options for Quick slide show in Options > View > Misc. > Quick slide show.
Dreamer
Troken
Post by Troken »
Dreamer wrote:There are no effects in Quick slide show and you can run it any time by Pause hotkey, you can find options for Quick slide show in Options > View > Misc. > Quick slide show.
Then the button in browser must have the wrong name. Now it says "Quick-show" but when clicking it opens a "Slide show". It should be changed in next version.
Dreamer
Post by Dreamer »
Sorry, I meant Viewer's Quick slide show.
I have a "Slide Show" toolbar button in the browser, where exactly do you have "Quick-show"??
Dreamer
Troken
Post by Troken »
Dreamer wrote:I have a "Slide Show" toolbar button in the browser, where exactly do you have "Quick-show"??
Oh weird, this explains some of the confusion of my posts... :? no I dont have a "Slide show" button, look at this print screen:
Pierre's error !
:) Hello !
• This is simply an error in the programme when you set button-texts !
- I checked here, the caption says wrongly "Quick Show" too here, while the “info-balloon” says "Slide Show" alright !
• Personally, I never enable the button-texts, that takes too much room and limits the number of icons (especially in View),
since that stands for all tool-bars.
:mrgreen: KR
Troken wrote:Oh weird, this explains some of the confusion of my posts... :? no I dont have a "Slide show" button, look at this print screen:...
This explains why my answer in topic 1.90 Translation questions & answers was not helpful... Good that Dreamer, Clo and you have found out. :-)
Troken
Post by Troken »
And I started to get paranoid, how could no-one understand my "simple" question? :D
I'm very fond of the "button-texts", hope this can be corrected to 1.90.3. Could you call it a bug (in that case; can this thread be moved to "bug reports"?)?
Right, i'll fix it
Troken
Post by Troken »
Fixed in 1.90.3, cheers! Case closed!
Guillo
Re: Difference between Slide show and Quick-show?
Post by Guillo »
So... how do you access the "slide show" in the current version??? (2010)
The buttons on my screen show no text, only icons, and that's only button I found that starts visualization.
From this thread description, I believe it is taking me to the Quik View, since I see no transition options or anything like that.
Thank you!
