Addons/Plugins/...
Re: Addons/Plugins/...
Hi
I can confirm that neither XnShell nor XnView show some reaction and it is not clear if it did something or not - and if it did something, what?
So yes, it would be fine if it would be fixed.
Peter
Peter
XnView 2.42 German, Win 7 x64 Prof. / Win 10
I almost wrote the blp plugin.(.usr) But I was stopped by these features.
- 1.XnView correctly opens [BLP1 JPEG & BLP2 dxt] itself, incorrectly opens [BLP2 paletted & BLP2 uncompressed] itself, and sends to plugin [BLP1 paletted & BLP2 JPEG]
- 2.When save 32-bit picture XnView shows "Save as - Colour mode..." and doesn't want to call any plugin's functions.(24-bits images properly saves)
- 3.When save 8-bit paletted picture, XnView sets has_colormap=false (gfpSavePictureIsSupported) and cmap (gfpSavePicturePutColormap) as pointer to zeroed data block.
Why XnView Classic CAN open images from NTFS hard links, but SDK's function LoadBitmap() CAN'T load bitmap when I provide NTFS hard link as name? With all my genius ideas about creating crutch XnView prefers to limp.
how do you open the hard link in XnView? PM doesn't work with you email...Mixer wrote:Why XnView Classic CAN open images from NTFS hard links, but SDK's function LoadBitmap() CAN'T load bitmap when I provide NTFS hard link as name? With all my genius ideas about creating crutch XnView prefers to limp.
RE: PM
I have.
I have.
If you're asking how do I open hard link, then I assume you know how to create them.xnview wrote:how do you open the hard link in XnView? PM doesn't work with you email...Mixer wrote:Why XnView Classic CAN open images from NTFS hard links, but SDK's function LoadBitmap() CAN'T load bitmap when I provide NTFS hard link as name? With all my genius ideas about creating crutch XnView prefers to limp.
And I'm opening them in very simple way, by choosing menu File->Open..., picking hard link to image file and clicking [Open] button. Or if hard link has any extension associated with XnView, I can just doubleclick it in Windows Explorer.
P.S. your PM worked, but I think PM's are not sent until recipient is logged in on forum.
i've sent a PMMixer wrote:If you're asking how do I open hard link, then I assume you know how to create them.xnview wrote:how do you open the hard link in XnView? PM doesn't work with you email...Mixer wrote:Why XnView Classic CAN open images from NTFS hard links, but SDK's function LoadBitmap() CAN'T load bitmap when I provide NTFS hard link as name? With all my genius ideas about creating crutch XnView prefers to limp.
Hi,xnview wrote:HEIF plugin added
I don't find the link for this plugin...
You'll find the link to the download (heif_x32.zip) in the original post.tomx82 wrote:I don't find the link for this plugin...
@Pierre: The link is missing on the official download page.
o Allows to send picture to a ImageShack/Imgur web service need update.
upload to imgur dose not run!
