Addons/Plugins/...
Addons/Plugins/...
Addons (must be in 'AddOn' directory)
Plugins (must be in 'Plugins' directory)
SDK for developer who wants to add new image format
Plugins user (must be in 'Plugins' directory with .usr extension)
  • Xasc by Nikolay Raspopov – Reading ASC, NFO, and DIZ files
  • Xhtm by Nikolay Raspopov – Reading HTML files
  • Xswf by Nikolay Raspopov – Reading SWF files (Macromedia Shockwave)
  • Xemfpcl by Oleg Kovalenko – Reading NT EMF Spool, PCL5 and HP-Gl/2, PCL6(XP) & ZjStream files format
  • XAwd by Boris Eyrich – Artweaver format
  • XPackRAW by Márcio Pais
Misc.
Re: Addons/Plugins/...
I've updated the plugin for HDPhoto http://www.xnview.com/download/plugins/wmp.zip
Post by Guest »
can you make sum of the this plugins into one big and simple .exe!!!!!
thanks, adios!!!
Anonymous wrote:can you make sum of the this plugins into one big and simple .exe!!!!!
thanks, adios!!!
Do you mean one big setup.exe (setup package) or one big xnview.exe (for execution)? I guess you mean the setup package. One big xnview.exe does not make much sense, because loading and start-up would take too long if everything was included into one executable.
The Complete version which you will find on the Official download page contains some of the plugins and addons, available. But from what I can see there is no version which contains all plugins and addons avaiable. And be aware that the complete version contains the English help document, only. Help documents in other languages are not included and most downloaded separately.
@Pierre:
Could you please give a precise information which plugins and addons are included in the Complete version?
Drahken
Post by Drahken »
helmut wrote: @Pierre:
I can...
- AddOns
7z.dll
id3lib.dll
NeroCD.lng
NeroCD.xnp
sqx20.dll
UNACEV2.DLL
unrar.dll
Unzip32.dll
Zip32.dll
ZIPPack.lng
ZIPPack.xnp
Reference This
Seems to have the nero addons, the archive addons, and the ID3 tag addon.
- Plugins
BMF_read.dll
CAD-License.txt
CADImage.dll
cpa.dll
CS_Manager.exe
DC120.dll
deco_32.dll
ecw-license.txt
fif-license.txt
jbig2dec.exe
jp2000-license.txt
ldf.dll
ldf_jpm.dll
libmng.dll
lwf.dll
lwf_jp2.dll
ncc.dll
pcdlib32.dll
slide.exe
WaveL.dll
Xbmf.dll
Xcompound.dll
Xeri.dll
Xfif.dll
Xfpx.dll
Xiwc.dll
Xjbig.dll
Xjng.dll
Xjp2.dll
Xjpegls.dll
XMrSid.dll
Xp2.dll
Xpax.dll
Xpwc.dll
Xsff.dll
Xsusie.dll
Xwhypic.dll
Xwic.dll
Xwlm.dll
Xwmp.dll
Reference This
hans-jürgen
Post by hans-jürgen »
By the way, can I simply create the AddOn subdirectory if it is not there and put the addons there? I didn't install the complete version, so I don't have this subdirectory yet.
ZZee ya, Hans-Jürgen
BLUEZZ BASTARDZZ - "That lil' ol' ZZ Top cover band from Hamburg..."
INDIGO ROCKS - "Down home rockin' blues. Tasty as strudel."
Drahken
Post by Drahken »
Yes.
Post by Guest »
still i cant use the hd photo plugin to write the files.. please help..?
Anonymous wrote:still i cant use the hd photo plugin to write the files.. please help..?
In your xnview.ini, try to remove the [plugins] section
Drahken
Post by Drahken »
That works. I haven't been able to use the plugin either, but I just figured it was a "read only" plugin.
EDIT: I must say I'm less than impressed with the format. It really isn't any better than plain old JPG, and distinctly worse than JPEG2000. Compress an image to about 3% of it's uncompressed size (or about 1/3 the size of a high quality JPG), this is the point where compression artifacts really become noticeable. The HDphoto image will have very blocky artifacts and lose a lot of detail in some areas, JPG with full subsampling enabled will have crappy looking reds but everything else will have less artifacting that the HDphoto one, JPG with no subsampling will have decent looking reds but about the same ammount of artifacting as the HDphoto, JPEG2000 will have decent looking reds far less artifacting and much less loss of detail, it's only drawback is it's slow compression speed.
Here's my comparison: http://rapidshare.com/files/32635854/HD ... arison.rar
Moderator & Librarian
Drahken wrote:That works. I haven't been able to use the plugin either, but I just figured it was a "read only" plugin.
Same thing here.
Deleting the following line from the [plugins] section of xnview.ini did the trick on my installation:
23=Xwmp.dll|262|wmp|WMP|wdp;hdp;
Obviously it was left behind by an earlier version of xwmp.dll. The next time I started XnView, version v1.90.4 of the plugin created a new entry:
23=Xwmp.dll|772|wmp|HD Photo|wdp;hdp;
Post by Guest »
thanks.. it worked .. i even erased the old xnview.ini to make a fresh one
I've added a FTP addon, and uploaded a new version of Paint
Drahken
Post by Drahken »
The paint plugin appears to be bug free so far.
I can't get the FTP plugin to work though. I extracted it to the addons folder, opened an image, but can't find the ftp option in view mode.
EDIT: I found it in the browser mode after remembering that the menus are often different. I take it it's only available in browser mode? Can it be made to be available in viewer mode?
Drahken wrote:EDIT: I found it in the browser mode after remembering that the menus are often different. I take it it's only available in browser mode? Can it be made to be available in viewer mode?
Ok
