Folder thumbnail
pdavit
Folder thumbnail
Post by pdavit »
Cannot find the option which displays the big folder icon which encapsulates
the 4 small sample images of its contents.
XnView 1.90 <x>
I hate so much the fact that I adore women!
Glasses ?
:) Hi Panos !
• Options Browser >> Thumb nail Tab : Appearance (displayed by default) >> [x] Show 4 thumbnails in folder…
:mrgreen: FR
Note : BTW, there a typo in your title here…
pdavit
Post by pdavit »
Where's that in latest beta?
Watch---
:) Please, watch below, it's in 1.90 ß-4 :
:mrgreen: FR
pdavit
Post by pdavit »
That was already checked without the effect. Is this a bug then! Was working fine in beta 3 and I thought another option was missing.
Bugbugbug !
:) It seems you are right, hence please, report this as a bug in the appropriate section.
- Paul and I can confirm then…
:mrgreen: FR
No panic ! It works in TC :P
pdavit
Post by pdavit »
Done!
marsh
Post by marsh »
pdavit wrote:That was already checked without the effect. Is this a bug then! Was working fine in beta 3 and I thought another option was missing.
I see 4 in 1 thumbnails. Not for JP2s though (seperate problem?).
Nothing at all
:) Hi B. !
• I confirm here again :
- I have not any thum nail on the folders in the thmb nails board !
¤ I tested with *.ico files, and there are a lot of folders¦sub-folders
¤ Folders are enabled in "Items Displayed", of course.
Note : BTW, you have moved the pdavit's separate bug report to “Closed…” ? :?
:mrgreen: KR
2 for 1 !
:) Solved, because there are two options @ two locations for the same thing !
• One needs also Options >>> Browser >>> File list >>> Items displayed >>> Tick the box in the column “Show as thumbnail” for Folders !
Paul "Ouistiti" discovered this and asked for I report it here.
- This is totally confusing, I think that as soon as the other option (on my pic above) is ticked,
then this one in Items displayed might be ticked too automatically… or might not exist !
- So, there is at least a misfeature which needs to be fixed up.
:mrgreen: KR
marsh
Re: 2 for 1 !
Post by marsh »
Clo wrote: - This is totally confusing, I think that as soon as the other option (on my pic above) is ticked,
If you disable that, 1 large picture is displayed instead of 4.
Inconsistent
:) When the tick-box is disabled in the Items Displayed >> Show as thumbnail, I get nothing on the folders, same @ Paul's - that is normal - but why is the option in Browser >> Thumb nail … able to be enabled ? It might be greyed, since no thumbnail is displayed according to the other setting !
:P So, there is a bug¦mess¦misfeature anyway. This is inconsistent.
:mrgreen: KR
pdavit
Re: 2 for 1 !
Post by pdavit »
marsh wrote:If you disable that, 1 large picture is displayed instead of 4.
No, if you disable that you don't get an images at all. Unless 1 means the
folder icon and not 1 image inside the folder icon.
So, Clo is right! It is still a bit confusing.
Maybe XnView should force select “Show as thumbnail” for Folders when a user
checks "Show 4 thumbnails in folder" cause otherwise the latter is non functional
without the former.
Re: 2 for 1 !
without the former.
Ok, i'll force it
Olivier_G
Re: 2 for 1 !
Post by Olivier_G »
Do you have Options>File List>Items displayed> Folders checked in both "Show item in view as thumbnails" and "Show as thumbnail" columns?
Olivier
