B2: Raised Toolbar Buttons on XP are Unavailable!
ckit
Post by ckit »
Steps:
- Open XnView in Browser Mode (WinXP SP2)
- Options -> Interface -> Toolbar
- Uncheck "Use Flat Buttons"
- Click OK and we still have flat buttons, the toolbar becomes a little higher in height and the dropdown list arrow for "File" is raised!
I have tested this on Win2000 Pro SP4 and the bug isn't present.
Pooooor !
:) Hello Chris !
• Here under XP-Pro, I can say that the "buttons" are drawn, but they touch ones others,
hence the “3-D” effect is pretty poor :
• One one hand, that saves space for more icons, but on the other hand, the aesthetic is not satisfactory…
- It was the same for several previous versions 1.8x
:mrgreen: KR
ckit
Post by ckit »
You're using WinXP SP1 aren't you?
If so, this suggests SP2 is the problem for WinXP.
SP1 sticked !
:) Yes, I run XP-Pro SP1, and I stick there…
- Friends (computing professionals) advised me to keep SP1,
just to avoid a lot of similar annoyances… :P
:mrgreen: KR
Re: B2: Raised Toolbar Buttons on XP are Unavailable!
ckit wrote:Steps:
Ok, right. In 1.82.4 too, only if you use xnview.manifest!
So the new Xp style doesn't like non flat button!!
ckit
Post by ckit »
Ok, I can confirm renaming the Manifest file does fix the bug.
XnView now needs a "Known Issues" text file to be packaged with it but that's only a suggestion.
ckit
Post by ckit »
Fixed in Beta 3.
