XnView 1.74 Release Candidate 5 (Windows)
Moderators: XnTriq, xnview
Post by xnview » Tue Oct 05, 2004 8:30 am
Normal users should use the current Final version of XnView, which is version 1.70.4. Please see post XnView 1.70.4 for details.
A RC5 (last before final release) is available here:
http://www.xnview.com/beta/XnView-RC5.zip
If you have found a problem, please have a look whether the problem has been observed and reported before. Then start a new topic in this newsgroup or append to an existing thread. Please do not reply to this topic.
Thank you & Regards. Pierre.
lawndart
Post by lawndart » Tue Oct 05, 2004 8:47 am
Menu size bug:
1. Select f10 details.
2. Deselect date and description columns.
3 Reselect date and description columns.
4. *Now the column size becomes extremely wide*
xnview.ini=
column0=141
column1=51
column2=80
column3=77
column4=7047856
column5=7047856
(Reducing last 2 values bring columns back in view)
Scan Headers in folders: fixed.
"dont start browser thumbnail" causes files not to be listed under
any other mode when starting browser from windows explorer right mouse click.
Post by xnview » Tue Oct 05, 2004 8:59 am
lawndart wrote:Menu size bug:
Ok, ;-)
lawndart
Post by lawndart » Tue Oct 05, 2004 9:25 am
1. Resize (enlarge) jpg.
2. Select smaller area.
3. Apply lossless crop. (Not sensible step for user to do here)
4. *Crash to desktop.*
lawndart
Post by lawndart » Tue Oct 05, 2004 10:02 am
When selecting area in middle of jpg using 4:3 ratio,
sometimes frames go off screen instead of stopping at
edge of picture.
And performing a lossless crop using 4:3 often crashes
program to desktop (when proper area within photo is
selected).
lawndart
Post by lawndart » Tue Oct 05, 2004 10:11 am
With lossless crop there appears to be a minimum amount
of area selected before change can be made permanent.
Just making a 922x783 photo into 914x783 by removing a
little from the left only will not stick.
Post by xnview » Tue Oct 05, 2004 10:25 am
lawndart wrote:With lossless crop there appears to be a minimum amount
Yes, lossless crop is 8 by 8 pixels.
lawndart
Post by lawndart » Tue Oct 05, 2004 11:44 am
When moving a selected area the dimensions are correctly
displayed on the botom right of status bar, this information
disappears when not moving frame with mouse. It should remain
even when not moving mouse, so you can see dimensions selected
without having to change them first.
Post by xnview » Tue Oct 05, 2004 4:01 pm
lawndart wrote:When moving a selected area the dimensions are correctly
The problem is that this field is reserved to show description :-(
lawndart
Post by lawndart » Wed Oct 06, 2004 9:06 pm
A couple of trivial things:
Changes to auto-refresh option take effect only after leaving and reentering
directory. This can trick users into thinking the function does not work.
Going to next file when deleting is always much slower than going to next file
without deleting.
Post by xnview » Thu Oct 07, 2004 8:07 am
lawndart wrote:Changes to auto-refresh option take effect only after leaving and reentering
Yes, a :bugconfirmed:
Going to next file when deleting is always much slower than going to next file without deleting.
Are you sure? It's the same function.
lawndart
Post by lawndart » Thu Oct 07, 2004 8:29 am
xnview wrote: Are you sure? It's the same function.
Yes its slower (win2k) even with auto-refresh off. Slower still with
autorefresh on.
SCR files are shown in file browser box, when recognize only by
extension is selected. This may be a problem.
On windows OS's, virus scans often find infected '.scr' files.
Is it safe for these to even show up in file browser?
The default (good) SCRs from windows system32 directory can
be invoked from Xnview.
Post by xnview » Thu Oct 07, 2004 9:00 am
lawndart wrote:[Yes its slower (win2k) even with auto-refresh off. Slower still with autorefresh on.
Do you have option "Go to next picture when deleting..."?
lawndart
Post by lawndart » Thu Oct 07, 2004 9:06 am
Yes, I have the goto when deleting option checked. Using the
delete key.
lawndart
Post by lawndart » Thu Oct 07, 2004 9:49 am
0. Show tooltips on.
1. Move mouse over jpg. Label pops up showing name, size, date.
2. Move mouse straight down to bottom of taskbar.
3. Same popup label is now shown on the taskbar (filename, size, date).
Normally, just titlebar info shows up on taskbar.
4. *Its stays there a fairly long time even when you try to select
something else on taskbar. When Xnview only displays titlebar
info here, it behaves normally and does not stay there as long.
-updated-
Locked
