I'm sure in the earlier version this didn't happen.. basically I'm sick of xnview defaulting to the center of an image..
example.. I'm looking at a lot of hi res photos 3000px+ and by default I have 'Auto Image Size' set too: Fit Window to Image. Now thats good, whats not good is that when I scroll the upto the top of the image, I am most likely going to also want to view the top section of the image that comes next in this photo set. But Xnview seems to like defaulting back to the center.. Same hassle in fullscreen mode..(although fullscreen mode works as it should when you open an image directly from the browser to fullscreen) I'm sure this didn't use to be like this and Xnview remembered these things in viewmode.
Another request is some sort of hotkey that can be set to use another 'Auto Image Size' preset... say I want to open further images in this view mode: 'Fit Image to window height. var width' I would like to be able to quickly set it too that option via a hotkey preferably(that applies on the current image too) instead of this labourious way of going into the options and changing such things...
B2: View Mode
nevermind.. should really have gone through all the options.. "Fit image to desktop , large only" is probably the best solution. Still would like to know if there are hotkeys to quickly change these settings on the fly... and maybe I could suggest some visual representation for each option like a small/animated image perhaps? ....
- foxyshadis
Hotkeys for different modes, plus a hotkey to sticky the mode, was also suggested here: http://newsgroup.xnview.com/viewtopic.php?t=10743
