Lossless crop and jpg files
Locked
lawndart
Post by lawndart »
Will lossless crop always result in smaller file sizes?
Sometimes jpg files increase in size after cropping with RC4.
(which I expect when images are reencoded).
Re: Lossless crop and jpg files
lawndart wrote:Will lossless crop always result in smaller file sizes?
Strange, size should be less???? When file size increase?
lawndart
Post by lawndart »
I think I had some larger jpgs increase in size by a large percent.
Here is a quick test of one jpg just show what my settings are:
800x600x24 161.63 original
(a desktop sreenshot using printscreen imported from windows clipboard)
(saved using xnews;jpg settings quality 94; optimize Huffman table)
(after cropping used 'save as', did not overwrite original)
794x596x24 164.14 crop 1 of original
797x596x24 162.49 crop 2 of original
793x591x24 161.04 crop 3 of original
797x598x24 162.47 crop 4 of original
796x597x24 164.98 crop 5 of original
Dreamer
I can't find "lossless crop"
Post by Dreamer »
I'd like to help too, but I can't find "lossless crop".
Can someone tells me where is it?
Thanks.
Re: I can't find "lossless crop"
Dreamer wrote:I'd like to help too, but I can't find "lossless crop".
Make a selection, and in jpeg lossless button (toolbar), you have crop
lawndart wrote:(after cropping used 'save as', did not overwrite original)
You use 'save as' after cropping???
lawndart
Post by lawndart »
xnview wrote: Make a selection, and in jpeg lossless button (toolbar), you have crop
My mistake. I have been using standard crop function.
I completelely missed the crop option under the jpeg lossless button.
(because it is found under the arrow, not popup transformations screen.)
So both crop functions seem to work as expected.
Dreamer
Post by Dreamer »
I suggest to add lossless crop to crop button too and to right mouse button - there is crop "normal" only (for possible conflits)
Also it looks, it's working good... thanks Pierre :D
Locked
