b2: Open all images with <enter>?
marsh
Post by marsh »
Opening all selected files using the <enter> key (in browser) is no longer possible because of a removed option. It is still possible using Menu>File>Open. Should the same default exist for browser?
Re: b2: Open all images with <enter>?
marsh wrote:Opening all selected files using the <enter> key (in browser) is no longer possible because of a removed option. It is still possible using Menu>File>Open. Should the same default exist for browser?
If you press shift, you can open all selected...
marsh
Post by marsh »
Thanks. That solves it.
