Few bugs...
Locked
Dreamer
Few bugs...
Post by Dreamer »
This is maybe a bug :bug: (maybe not) - sure not big - take a look at that, please.
Another (known) bug :bug: It's still here and I can see this bug all the time :( (because I don't use a folder tree) so it would be nice if it could be fixed in this version :wink: , but if not, there's nothing doing, I understand :)
Also, it was somewhere, could you add/fix copy (ctrl+c) and move for folders too, please (because it seems that it's possible - in right click menu but it's not - so it's confusing...) :?:
Thank you very much :)
P.S.
I've just found a new bug - It's in new "right mouse button menu" - copy, move... feature (thanks a lot for it :wink: )
If I want to copy an image, I choose "Copy" from menu, then I go to another folder and I want to paste it, but "Paste" is missing in the (right mouse button) menu.
In the main program menu - "Edit" -> "Past" it's there, also a hotkey ctrl+v works good.
Re: Few bugs...
Dreamer wrote:Another (known) bug :bug: It's still here and I can see this bug all the time :( (because I don't use a folder tree) so it would be nice if it could be fixed in this version :wink: , but if not, there's nothing doing, I understand :)
Sorry i can't for this release.
Sorry i don't understand, what must be fixed?
Ok, i'll add it
Dreamer
Re: Few bugs...
Post by Dreamer »
xnview wrote:
Dreamer wrote:Also, it was somewhere, could you add/fix copy (ctrl+c) and move for folders too, please (because it seems that it's possible - in right click menu but it's not - so it's confusing...) :?:
Copy with a hotkey ctrl+c, cut with a hotkey ctrl+x and paste with a hotkey ctrl+v - works with files, but don't works with folders (directories).
Also copy, cut (and paste) right mouse button menu features works with files but not with folders.
Hope you understand now, I can't find where it was...
Thanks.
Re: Few bugs...
Dreamer wrote:Copy with a hotkey ctrl+c, cut with a hotkey ctrl+x and paste with a hotkey ctrl+v - works with files, but don't works with folders (directories).
Oh yes, ok. Currently, copy/move folder is not possible.
Dreamer
Re: Few bugs...
Post by Dreamer »
And will be :wink: :?:
Locked
