B1: Ghost background whithout viewer toolbar.
marsh
Post by marsh »
1. Disable toolbar only in viewer.
2. Switching mode = Browser>Fullscreen>Viewer
3. Choose file using <enter> and start viewing.
4. *Now when viewer mode is reached, the desktop view of browser bleeds through onto the the lower portion of viewer right above status bar. The portion where the desktop filters through is the same height as toolbar would have been. I can post image of this if needed, unless someone else wants to do it.
ckit
Post by ckit »
I cannot reproduce this bug.
Olivier_G
Post by Olivier_G »
ckit wrote:I cannot reproduce this bug.
Same here.
Olivier
marsh
Re: B1: Ghost background whithout viewer toolbar.
Post by marsh »
marsh wrote:1. Disable toolbar only in viewer.
... while leaving it enabled in browser. A new feature- you could not disable them seperately before.
Olivier_G
Post by Olivier_G »
Yes, I understood this way... but didn't get the bug.
Olivier
Right here---
:) Hello !
• Tested here like marsh says, I cannot reproduce the bug disabling the tool-bar in “View” only… :?
:mrgreen: KR
I can't reproduce it, and could you post a screenshot...
marsh
Post by marsh »
Screenshot:
(I was using layout 3, which shows through at bottom portion of image)
ckit
Post by ckit »
Does this happen with a fresh INI config?
marsh
Post by marsh »
ckit wrote:Does this happen with a fresh INI config?
Yes, after following settings are also changed:
1. Disable Tabs= Then you'll see blank toolbar on top when it should be disabled.
2. Browser> Fullscreen >viewer= As shown above.
ckit
Post by ckit »
Can you post your INI file for us to play with?
So far, I cannot reproduce this bug at all.
GeorgD
Post by GeorgD »
marsh wrote:1. Disable Tabs= Then you'll see blank toolbar on top when it should be disabled.
I did so by Menü-view-tabs (remove checkmark).
I can reproduce it with 1.9b2 on WinXP SP2 but get a slightly different look (two horizontal rules that make no sense), see Image
And how do you reproduce it?
GeorgD
Post by GeorgD »
xnview wrote:And how do you reproduce it?
Just like described in the above posts:
Take a fresh 1.90beta 2 and change those options:
Then do
3. Disable Tabs by Menü-view-tabs (remove checkmark).
4. Choose file using <enter> and start viewing until you reach view mode
I get the error I posted a screenshot of, marsh gets another, but this just tells: There is a bug with different symptoms.
marsh
Post by marsh »
GeorgD wrote: I get the error I posted a screenshot of, marsh gets another, but this just tells: There is a bug with different symptoms.
It is fixed for me.
