B1: Issues with Thumbnails labels (back color, customs)
sullysnet
Post by sullysnet »
thumbnail label - text back color is not working (has been since alpha) not sure if this was something that was reported. I use this but others may not. The tan color throws me off :) also most of the custom settings can't be saved again this might be a known issue just pointing it out :)
thanks and keep up the EXCELLENT work one of my favorite apps ever
ckit
Post by ckit »
sullysnet wrote:thumbnail label - text back color is not working (has been since alpha) not sure if this was something that was reported. I use this but others may not. The tan color throws me off :)
Well spotted!
It's not working for me either.
sullysnet
Post by sullysnet »
I updated my list or I can make a list but most of my custom settings do not take. Like if I make my left mouse on picture view move the picture instead of selecting it. After I OK to the setting and go to try it ... it doesn't take.
sullysnet wrote:thumbnail label - text back color is not working (has been since alpha) not sure if this was something that was reported. I use this but others may not. The tan color throws me off :) also most of the custom settings can't be saved again this might be a known issue just pointing it out :)
I have no problem with this setting... Text back color is used for format not recognized, else you must disabled FileList/Use color based...
ckit
Post by ckit »
Ah, of course silly me!
No bug, false alarm :)
ckit
Post by ckit »
sullysnet, can you make a post so we can then move this to closed.
Olivier_G
Post by Olivier_G »
Normal feature of XnView -> moved to 'Closed'.
(but a confirmation by sullysnet is still welcome...)
Olivier
sullysnet
Post by sullysnet »
sorry that I didn't reply earlier, once your remove a certain setting you can utilized the colors :)
thanks I wasn't aware of the setting
